Author Topic: Help me with identifying object, 898 SI.  (Read 21074 times)
Offline Arti
  • Unit(s): 898
« on: September 30, 2012, 12:57:04 AM »
Hi!
Any ideas about what it could be?
Certain object (right side):
Two bright parallel strips are visible:
Can it be noise or something natural?
Or it is more like artificial object?
Can it be fishing net, for example?
Or it must be more solid to be visible by 898 SI sonar?
Thanks a lot!
« Last Edit: September 30, 2012, 01:05:16 AM by Arti »
Offline Rüdiger
Re: Help me with identifying object, 898 SI.
« Reply #1 on: September 30, 2012, 03:37:50 AM »
Hi Arti
Welcome to the forum :)
No natural object, perhaps a gill net.
mvh
Rüdiger
Finding is better than losing
Offline Arti
  • Unit(s): 898
« Reply #2 on: September 30, 2012, 05:31:53 AM »
Hi Rüdiger!
It can be a net. I saw small fixed buoys on the water surface and vertical wooden sticks.
So is it true that Humminbird 898 SI (for example) can spot fishing net and it can be visible?
Actually I was not sure it can.
Offline Roddy
  • Scan,scan and rescan
« Reply #3 on: September 30, 2012, 05:50:31 AM »
Arti welcome! I counted three (3) flot with lines going to the gill net.
Roddy
Scan,Scan and Rescan Roddy
Offline Arti
  • Unit(s): 898
« Reply #4 on: September 30, 2012, 06:41:05 AM »
Thank you Roddy!
Roddy
3 float with lines - do you mean these horizontal lines (see attachment with red arrows)?
Am I right that this net is at the bottom? Or not?
And what do you think of first and second images? Also the net from differend angle? Or maybe something else? My friend said that he clearly see something different (even a vehicle) there but I suppose that he has very good imagination. :)
« Last Edit: September 30, 2012, 06:50:58 AM by Arti »
Offline Roddy
« Reply #5 on: September 30, 2012, 01:18:23 PM »
Arti, Yes the red arrow's are spot on.
A good imagination helps a lot!
Roddy  >:D
Last post August 22, 2011, 10:29:52 PM
by Roddy
Last post April 28, 2011, 04:06:07 AM
by tmx
Last post September 08, 2011, 12:09:57 AM
by Roddy
Last post May 14, 2012, 11:31:47 AM
Last post December 29, 2015, 06:58:31 AM
