Author Topic: Y cable question  (Read 10240 times)
Offline hgv
  • Unit(s): 798ci HD SI
  • Software: 6.x
Y cable question
« on: August 20, 2012, 01:42:46 PM »
My boat has an older flasher built into the dash. It also has a thru hull transducer. I recently purchased the 798ci SI HD unit and its transducer is mounted on the transom. Is it possible to "Y" the flashers data into the 798 so that while on plane I cabn measure depth / utilize the thru hole transducer?
Offline bobxxx
  • Unit(s): hb798cihd,hb helix9 si di mega,helix7 si
  • Software: 6.61,1.160,1.84
  • Accessories: AS GPS HS
Re: Y cable question
« Reply #1 on: August 20, 2012, 10:17:01 PM »
doubt if the ends would even match.
Offline terry0540
  • Unit(s): 798ci SI NVB
  • Software: 4.780
  • Accessories: none
« Reply #2 on: August 21, 2012, 09:47:21 AM »
I have a 1999 model boat that came with a Humminbird and I am using its trandsducer and "Y" cable with my 798 with no problems
Offline Roddy
  • Scan,scan and rescan
« Reply #3 on: August 21, 2012, 10:38:11 AM »
hgv, Whate modle number flasher do you have?
I think the cable ends won't mate up from a old flasher to the Y-Cable. :'(
If you can post a pix of the flasher cabls end.
Roddy
« Last Edit: August 21, 2012, 10:41:48 AM by Roddy »
Scan,Scan and Rescan Roddy
Offline hgv
  • Software: 6.x
« Reply #4 on: August 21, 2012, 01:32:37 PM »
I will get the model number of the flasher tonight and post it,  thanks
« Reply #5 on: August 21, 2012, 01:34:20 PM »
Like others have said: it depends on the connector end of the flasher’s transducer.  We may still have soma adapters that may allow older transducers to work but they may also be limited to using only the 200kHz sonar versus the 200kHz and 83kHz sonar of the correct transducer.
Post an image of the transducer connector as well as the full model name of the Flasher unit.
Offline hgv
  • Software: 6.x
« Reply #6 on: August 21, 2012, 04:55:16 PM »
OK will get that info tonight.
I would be happy with just the flasher on the 798 working while on plane
Offline hgv
  • Software: 6.x
« Reply #7 on: August 21, 2012, 09:07:27 PM »
It is a Lowrance Bluewater Pro 1220 :(   :'(   :(      I would have swore it was a humminbird, crap
Last post April 23, 2012, 03:16:13 PM
Last post June 14, 2012, 12:13:15 PM
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post January 23, 2013, 05:13:42 AM
by hvychev77
Last post January 25, 2013, 04:15:45 PM
Last post April 28, 2014, 02:56:12 PM
by RedHawks22
Last post March 24, 2015, 12:54:20 PM
Last post August 12, 2020, 11:29:34 PM
