Author Topic: 998 snapshot/recording help?  (Read 8397 times)
Offline fishinman
  • Unit(s): 1
« on: July 10, 2012, 07:16:15 PM »
Can't get menu for this to come up.....have tried formatting new SD card etc.... But when I go to set a waypoints/record I get a message that says "writeable card" not installed.....snapshot set to visible also ....anything else I'm missing? Thought I followed manual instructions ....
Re: 998 snapshot/recording help?
« Reply #1 on: July 10, 2012, 08:11:36 PM »
Make sure you format the card for fat32.
what size and type of card is this..?
Does the card seem to go into the slot ok and not pop out when the door closes.
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
« Reply #2 on: July 10, 2012, 11:20:30 PM »
Hi Fishinman,
- Is the write-protection tab on your SD-Card by accident set to the "Locked" position?
- Can you see the card and format it from your computer using Humminbird PC?
Tore
Offline fishinman
  • Unit(s): 1
« Reply #3 on: July 10, 2012, 11:50:36 PM »
Thanks for the replies.....card not locked....It is a new 1gb scan disk.....but, I haven't formatted using hummingbird pc...,have only formatted using my computer and even used my camera....again thanks....
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #4 on: July 11, 2012, 12:08:45 AM »
Make sure the card slot you're using is not set for map card only. Most map cards are set to read-only (locked). So, I would try the other slot or check/change the settings in regards to map slot.. .Also make sure the cards are not bumped while closing the card door.
« Reply #5 on: July 11, 2012, 01:37:37 PM »
A 1GB SD card should be formatted to the FAT16 setting.  FAT32 is for the larger capacity SDHC memory cards (2GB and up).
Did the 1GB SD card work in your camera?  Test it and see if it does, then format it (FAT16) and try it in your unit again.
Last post February 03, 2010, 09:51:07 AM
Last post February 16, 2010, 07:50:47 AM
Last post February 14, 2010, 03:16:32 PM
Last post April 29, 2011, 07:20:26 PM
by calli1
Last post May 29, 2012, 03:00:47 AM
by Rüdiger
Last post July 08, 2012, 05:39:58 PM
by Fay
Last post May 16, 2015, 11:57:03 PM
by GillWill
Last post July 09, 2019, 11:23:20 PM
by Fly 1
