Author Topic: No Temperature ??  (Read 9261 times)
Offline oz
  • Unit(s): 898si
No Temperature ??
« on: June 27, 2012, 04:05:13 PM »
Hi Guys I have an 898 si combo. . I had a pro instillation and we are using the Humminbird XPTH-9-HDSI-180-T
I dont have any temperature readings ?
Any advice ?
cheers
Oz
Re: No Temperature ??
« Reply #1 on: June 27, 2012, 04:33:35 PM »
Check the Accessory Test View to see if the Temperature is listed as connected or unconnected.  If connected; go to the Select Readouts and set one of the digital readout areas to display temp.  If unconnected: contact Humminbird for a replacement transducer as the temperature sensor in yours is bad.
Offline oz
  • Unit(s): 898si
« Reply #2 on: June 27, 2012, 04:38:33 PM »
Thanks I will do that!
« Reply #3 on: June 27, 2012, 07:09:54 PM »
there are other posts and on other forums that are pointing to defective temp sensors on the HB transducers.
suggest you contact your dealer and have him replace...
chuck
Offline oz
  • Unit(s): 898si
« Reply #4 on: June 28, 2012, 01:20:43 AM »
THanks
Will Humminbird pay for the removal and instillation ?? Having paid top money I would be reluctant to start ripping it all out and re installing myself. I have it fitted onto my gill bracket
Offline oz
  • Unit(s): 898si
« Reply #5 on: June 28, 2012, 08:19:30 AM »
Select Readouts
That worked and I now have a temperature .
Thanks for the advise !!
Last post May 13, 2013, 09:29:14 AM
Last post August 11, 2013, 07:55:54 AM
by snowman48047
Last post July 13, 2013, 11:31:33 PM
Last post March 17, 2014, 10:55:29 AM
Last post April 15, 2014, 10:39:12 AM
Last post June 03, 2014, 11:52:29 AM
by snowman48047
Last post March 02, 2016, 11:17:32 PM
by Birdhunterden
Last post January 01, 2019, 08:18:11 PM
by Sodaksam
