Author Topic: Mac Address Conflict  (Read 4814 times)
Offline Vinniez520
  • Unit(s): 3 10" Onix
  • Software: 2.300
  • Accessories: 360
« on: June 26, 2012, 06:31:59 PM »
Anybody ever  hear of this?? I have 2 1197 hooked up with either net cable??? Need help???????
Re: Mac Address Conflict
« Reply #1 on: June 26, 2012, 08:35:01 PM »
What is the exact problem?  Do you have an error code or indicator..
What is the code level installed on your units..?
« Last Edit: June 26, 2012, 08:36:08 PM by sonar2000 »
Offline Vinniez520
  • Software: 2.300
  • Accessories: 360
« Reply #2 on: June 26, 2012, 08:46:24 PM »
I had the same problem earlier, so I installed the lastest update and this message comes right across the screen??
« Reply #3 on: June 27, 2012, 02:42:50 PM »
Did you disconnect the InterLink?
Both units are running the latest software, correct?
Try resetting to the factory defaults on both units while they are disconnected from each other and try them again.
