Author Topic: First time user  (Read 12507 times)
Offline titansfan2104
  • Unit(s): 998c si
  • Software: 6.180
  • Accessories: sandisk xtreme pro 45mb 8 gb
First time user
« on: April 07, 2012, 11:27:32 PM »
I made two recordings today and did not actually stop recording with the unit. I just powered down and hummviewer will not open the .dat files but they play on the unit itself. Is there any way to rename the files or "close" them so that hummview will recognize them. I have some pretty good stuff and hope  i can save it ... THANKS
  • Unit(s): 998c si
  • Software: 6.180
Re: First time user
« Reply #1 on: April 08, 2012, 12:57:02 AM »
I edited the .dat file of my two recordings with the the info from a properly recorded/ stopped clip and changed the number to correspond with the two recordings I made earlier today. It loaded each with an error message and played the recording although playback quality was pretty bad. Nowhere near how it looked today on the hb unit. Any suggestions how to clean it up or os it just the nature of the beast? Thanks
Re: First time user
« Reply #2 on: April 08, 2012, 04:25:06 PM »
Humviewer should be a good view, in fact maybe a bit better than the unit..because of a larger screen possibly.
I suppose you can rename the files but I would suggest leaving the names as they  are and putting them in a descriptive file name.
C:\sonarrecords\lake Richie\04072011\
Can you have humview make a picture of your record and post here.
  • Unit(s): 998c si
  • Software: 6.180
Re: First time user
« Reply #3 on: April 08, 2012, 04:53:12 PM »
It's not a matter of renaming. The files were I powered the unit down didn't "close"  kinda like when you burn a dvd and it closes the process so it can be read on another machine. These files didn't have any data inside the r00004.dat files. So I copied the info and edited the bad files with the info from the good file and it worked but can assure you that quality is no where near as clear as it was on my unit at the time.
« Last Edit: April 08, 2012, 04:54:25 PM by titansfan2104 »
Re: First time user
« Reply #4 on: April 08, 2012, 04:55:26 PM »
OK...can you post a picture from the screen..
A play back should be the same as a recording..
« Last Edit: April 08, 2012, 04:56:58 PM by sonar2000 »
Last post May 19, 2010, 04:14:54 PM
Last post April 12, 2014, 08:25:00 PM
by Gimp
Last post February 04, 2015, 10:44:43 PM
Last post January 27, 2016, 01:51:40 PM
by CamoHunter
Last post May 06, 2015, 05:02:20 PM
Last post April 22, 2016, 04:00:51 PM
by avetjx
Last post April 21, 2020, 11:40:52 PM
Last post May 16, 2020, 08:45:51 AM
