Author Topic: DSC Radio Connection  (Read 8866 times)
Offline autoculto
  • Unit(s): 897csi
  • Software: unknown
« on: April 06, 2012, 03:11:58 AM »
NMEA pigtail out are black, white and green but everywhere i look they are black, white and red. Does anyone know which wires i need to connect to the radio?
In the manual it says the red wire is 12v but i have no voltage from any of the 3 wires. Does it need to be turned on somewhere in the menus option?
« Last Edit: April 06, 2012, 02:11:45 PM by autoculto »
Re: DSC Radio Connection
« Reply #1 on: April 06, 2012, 04:05:51 PM »
You have a GPS Receiver with the newer wiring harness.  It has no Red (+12V) wire.  Nothing else has changed though so you still need to connect the same White and Black wires for NMEA Out and Ground.
The NMEA Output menu still needs to be set to "On" as well.
Offline autoculto
  • Unit(s): 897csi
  • Software: unknown
« Reply #2 on: April 06, 2012, 04:10:37 PM »
Hi Greg
How do i get into the NME menu?
« Reply #3 on: April 06, 2012, 04:24:58 PM »
Look under the Setup menu tab in your unit.  Your unit will have to running in the Advanced setting for the User Mode menu to see it though.
Offline autoculto
  • Unit(s): 897csi
  • Software: unknown
« Reply #4 on: April 06, 2012, 04:40:53 PM »
Ok thanks for that greg.
« Reply #5 on: April 06, 2012, 04:46:34 PM »
Under the setup menu look for USER MODE and make sure you have this set to ADVANCED.
then a little farther down you will see NMEA. turn this to onb.
When you have highlited the specific tab use the left or right cursor key to make your selection
chuck
Last post July 15, 2011, 01:00:23 PM
by edwardpic
Last post March 16, 2012, 06:59:31 PM
by wolfs4evr
Last post March 22, 2012, 07:47:53 PM
by Gattlin
Last post July 30, 2012, 07:43:18 PM
by LocDown
Last post November 25, 2012, 06:59:54 PM
by flatcat_auz
Last post June 29, 2014, 06:36:37 PM
by jjmoney
Last post January 27, 2016, 11:30:58 PM
Last post August 28, 2021, 07:38:11 AM
by 6speedy3
