Author Topic: 997C  (Read 10334 times)
Offline hickory
  • Unit(s): 997c
  • Software: 4.75
  • Accessories: None
997C
« on: March 06, 2012, 09:06:13 PM »
Putting my 997C on my boat this year,I noticed a 1/8"x3" line on the top left corner running along the top of the unit.Down the left side there are three 3/8" circles running down the left side.The lines look like air bubbles or water behind the screen.When I push on the water or air marks nothing happens.Whats wrong and will this affect the unit in any way.
Re: 997C
« Reply #1 on: March 08, 2012, 02:08:42 PM »
Can you post a picture of what you are seeing?
Re: 997C
« Reply #2 on: March 08, 2012, 02:51:54 PM »
I have seen that in some units.  It is an imperfection in the bonding process or what ever it is called.
Not a very prevelant issue but it does happen.
Sometimes this happens after the unit has been exposed to temperature.
How old is the unit and when did it first show up..?
Offline hickory
  • Unit(s): 997c
  • Software: 4.75
  • Accessories: None
Re: 997C
« Reply #3 on: March 08, 2012, 08:12:20 PM »
997c  "Chuck"  Took the unit  off my boat last fall.Put it in the closet.The unit is 5 years old.Went to put the unit on my boat last week and noticed the water or air bubble marks under the screen.
Re: 997C
« Reply #4 on: March 09, 2012, 09:00:05 AM »
might be an aging issue.
If it does not prevent you seeing the display then keep on with it.
If it gets worse then it might be time for a new unit.... :P
Offline George
  • Software: Always up todate
Re: 997C
« Reply #5 on: March 09, 2012, 10:50:42 AM »
hickory
If the screen is an issue, contact customer service and they will repair or replace the unit 997c SI for $260.45, they will send you a form and give you shipping instructions for the unit only.
Return Form (pdf) remember you need to talk to them first to firm up costs, etc.
-->  http://www.humminbird.com/uploadedFiles/Humminbird/Support/Service_Forms/RepairReturnForm.pdf  <--
Current flat rate charges can be reviewed
-->  http://www.humminbird.com/Faq.aspx?TaxonomyId=95A1764  <--
« Last Edit: March 09, 2012, 11:04:01 AM by George »
Offline hickory
  • Unit(s): 997c
  • Software: 4.75
  • Accessories: None
Re: 997C
« Reply #6 on: March 09, 2012, 08:51:55 PM »
997c  Cuuck,you would think a unit that I paid almost $1800.00 for would last more than 5 years.I know guys that have there unit much longer and they never take it off their boat.Maybe that's where I went wrong,I should have left it on the boat.
Re: 997C
« Reply #7 on: March 10, 2012, 10:49:02 AM »
Hickory....I agree in the time frame concern. But I do worry sometimes in warrenties that are less than a year in length. Look at cars for another example...
Extending warrenties can also add to the cost..
I would take this up with customer service and at a management conversation level. Some one who has been empowered by HB to speak and make decisions.
Offline hickory
  • Unit(s): 997c
  • Software: 4.75
  • Accessories: None
Re: 997C
« Reply #8 on: March 10, 2012, 09:27:54 PM »
Chuck,thanks for your help.  Hickory
Last post April 09, 2014, 06:22:56 PM
Last post January 31, 2015, 11:12:37 AM
Last post August 18, 2015, 02:31:01 AM
Last post November 24, 2015, 02:00:29 PM
Last post January 04, 2016, 11:23:27 PM
by 49thdiver
Last post September 17, 2017, 06:04:58 PM
Last post May 05, 2019, 09:40:56 PM
by Delta Bass Fool
Last post April 14, 2023, 06:44:50 PM
by DiveExplorer
