Author Topic: ALL SI Models - Add a user reset feature  (Read 13668 times)
« on: October 19, 2011, 04:18:10 PM »
Model:
ALL SI Models
Suggested Upgrade:
Explanation:
Add a menue selection to reset the unit to raw factory setting.
Allow for clearing clogged real memory.
Allow for clearing corrupted data fields in memory.
allow for a clearing of all memory and the capability to load anew level of code to refresh the cleared memory.
Added in Software Version:
Comments on Update:
Re: ALL SI Models - Add a user reset feature
« Reply #1 on: October 20, 2011, 08:28:50 AM »
Chuck,
If a waypoint is corrupted, it will load it back in and freeze up the system again.
What you asked for isn't enough in my opinion.
I think we need an item to delete ALL NAV data from the system.
Add a warning that if the data is not backed up to an SD card, that
it will be lost forever.
« Last Edit: October 20, 2011, 08:36:11 AM by ITGEEK »
« Reply #2 on: October 20, 2011, 09:26:23 AM »
Exactly ITG...if a waypoint corrupts the unit then "reset" and dont load the sd card..fix the sd card externally on a pc.
dont keep freezing the unit...
« Reply #3 on: October 20, 2011, 10:42:35 AM »
Yes,
But the waypoints are stored in the unit on the hard drive/flash drive
until they are deleted by the user.
Most likely, they are loaded into memory everytime a system re-boots.
I don't think doing a reset will accomplish much if a corrupted waypoint is loaded back
into memory again from the unit.  It would freeze up the system again and again.
It would only be a last ditch effort to try something before having to send a unit back to Humminbird.  Would have to use the feature very rarely, I would expect.
« Reply #4 on: October 20, 2011, 11:03:56 AM »
Yes, that is what I am saying.....reset the unit hard drive locations..   do not load any waypoints, or information from the sd until the sd is cleaned....
I wish it was like a computer where we could write zeros in all positions then boot strap in a code to load the operating code for what ever release we decided.....
after all this is really a computer...........
Last post June 29, 2012, 06:51:33 PM
by W9GFO
Last post February 02, 2013, 10:10:24 PM
by ScottMN
Last post April 12, 2014, 08:25:00 PM
by Gimp
Last post May 18, 2014, 07:59:29 PM
by Scrutch
Last post July 30, 2016, 01:27:51 PM
by Sawbones
Last post August 07, 2016, 07:37:12 PM
Last post October 29, 2019, 12:20:48 PM
Last post July 18, 2019, 10:18:04 PM
by danceswithbass
