Author Topic: Power Pin Corrosion?  (Read 10437 times)
Offline linchuntao
« on: October 16, 2011, 08:19:58 PM »
I have a Humminbird 798 HD ci si mounted on my kayak. After 4 hours of the first trip in the ocean, I noticed some green liquid on my kayak. I checked everything after the trip. I found the one of the two power pins (the two pins on the unit end of the power cable, which can be plugged into the power port the of the 798 unit) has a green coat on the pin metal. The other pin has some kind of white/gray coat on the pin metal. Now the "green" pin has a much smaller diameter than that of the "white/gray" pin. I think this is caused by corrosion? The question how to avoid this? If this happen again, the "green" pin could totally disappear at its 2nd ocean trip on my kayak.
Offline Roddy
  • Scan,scan and rescan
Re: Power Pin Corrosion?
« Reply #1 on: October 16, 2011, 10:46:57 PM »
Yep! Salt water and DC power + Hot wire power leek = electrolysis.
1. Replace pins.
2. find and fix the power leek.
Radio Shack has pins that slip on and pinch tight.
Good luck Roddy
Scan,Scan and Rescan Roddy
Offline linchuntao
« Reply #2 on: October 16, 2011, 11:45:15 PM »
Thanks Roddy. Regarding the "hot wire power leak", I think it is because some salt water comes into the two power pins? Looks like all ports, including power input port as well as sonar data input port, on Humminbird 798 are not water tight. I also have Lowrance hds8 with structure scan. All of connection ports on Lowrance are water tight, but it's too big for my kayak. I am not sure how to fix this to make my 798 connections water tight. Any suggestion?
Offline Roddy
« Reply #3 on: October 17, 2011, 01:58:52 AM »
Vaseline gel, white grease, wax or replace the El Cheapo HB plugs.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #4 on: October 17, 2011, 05:51:56 AM »
Roddy go to any automotive store an get some Dielectric grease it will stop that issue. I have used
it for years. Gary
Offline Roddy
« Reply #5 on: October 17, 2011, 11:02:40 AM »
Thanks stillbear, I'll try it.
Last post December 20, 2010, 10:21:35 AM
Last post August 02, 2011, 01:10:37 PM
Last post March 04, 2012, 10:00:45 PM
by oz
Last post April 12, 2012, 05:51:49 PM
Last post July 24, 2012, 11:31:27 AM
by Roddy
Last post March 26, 2012, 08:37:43 PM
Last post May 05, 2012, 08:11:19 PM
by depark1
Last post May 03, 2013, 08:15:30 AM
by George
