Author Topic: Weather alerts problem  (Read 7325 times)
Offline Jim Pauley
  • MasterCatters2 Admin
  • 67.25 blue from the James River
    • MasterCatters2
  • Unit(s): matrix 37, 797csi,530
« on: September 26, 2011, 07:23:42 AM »
finally got the new bird on the water over the weekend, for the most part its working pretty good except for all these nagging weather alerts that keep popping up in the middle of the screen, dust storms, tsunami, freezing spray you name it they all pop up randomly and will build up until you clear (exit) all of em, is there anyway to turn off the alerts. yes I have both the weather sense and the sirrus puck on the unit.
Re: Weather alerts problem
« Reply #1 on: September 26, 2011, 08:03:49 AM »
The only thing you can do is set the alert radius to the
lowest setting.  I think it's 60 miles.
However, you'll have more time to react to bad weather if you
set it further out.
Offline Jim Pauley
    • MasterCatters2
« Reply #2 on: September 26, 2011, 08:24:47 AM »
well I would buy that, but it was allready on the lowest settings, and sometimes without the weather aids connected, gotta be some stray signal or bit causing the problem
« Reply #3 on: September 26, 2011, 09:27:54 AM »
While looking at your boat icon on the XM weather map:
If you have a bunch of little red boxes in and around your area, then this
is the area that the alerts are coming out for.
Offline Jim Pauley
    • MasterCatters2
« Reply #4 on: September 26, 2011, 10:02:53 AM »
Nope, didn't have that on the map, just the alerts kept popping up and to get rid of them you have to keep acknowledge them by pressing the exit key.  I'm sure it wasn't weather related.  Where does the alert messaging window get its input from to trigger? the xm weather antenna? remember I get these alerts without the antenna connected and even in the parking lot without the engine running of course.
« Reply #5 on: September 26, 2011, 10:56:33 AM »
That's really weird.
Without the XM antenna being connected, does your system still show that you
have XM weather?
I'm thinking maybe there is some kind of internal loop going on.
Maybe if your system thinks that XM is hooked up and it's not,
it may be generating the last set of warnings.
Not sure.
Maybe it's not a good idea to disconnect the XM module once your have
initially connected it and registered with XM.
Call HB support and they might know something.
Offline axman
  • Unit(s): 898SI
  • Accessories: XM weather
« Reply #6 on: October 04, 2011, 10:04:43 PM »
My unit does the same thing can use it for all the warnings. Checked connections all hooked up even sent unit back everything checked out . Thought about canceling the XM service just to see if the warnings would stop . Have no idea what to do . It says Check antenna and will have full bars on signal strength wish there was a mode that would cut the weather function off .
Offline George
  • Software: Always up todate
« Reply #7 on: October 05, 2011, 04:11:53 PM »
I ended up removing my XM weather alert found it to be more of a nuisance.
The heat alerts alone was a pain in the neck, I know it is hot and do not need these types of alerts.
I really only wanted it for lightning and high wind warnings, but the system is not adjustable to control which alerts we want.
Maybe if they make adjustments to the system I will restart it, right now I would rather fish without the aggravation of the XM weather alerts.
Offline axman
  • Unit(s): 898SI
« Reply #8 on: October 05, 2011, 06:27:54 PM »
How do you remove the alerts i cant find it in the menu . Can you just unplug the antenna?
Offline George
« Reply #9 on: October 06, 2011, 07:28:39 AM »
I unplugged my XM receiver and everything disappeared from the system's menu.  I have also stored the receiver just in case I decide to try it again, it could be a great tool for safety.
Hopefully XM will make adjustments to their system so that we can decide on which alerts we want.  We have a lot of lightning and tornadoes in Oklahoma, lightning and high wind warnings are what I need.  I know when it is hot, cold and raining, these are not life threatening on the water.  When uncomfortable I can get off of the water.  I don't want to be dodging lightning or fighting high winds to get to a safe place.
Offline Jim Pauley
    • MasterCatters2
« Reply #10 on: October 26, 2011, 09:15:04 AM »
I unplugged my antenna as well and the alerts went away, so I suppose I gotta send that unit back,  Yea I agree with more controls over those alerts for the future.
« Reply #11 on: October 26, 2011, 09:19:57 AM »
I am not sure of more control as it may be more interface (talk) between service offering companies. It seems none of these guys talk to each other about what they want to do.,
A more coordinated conversation might result in things working much better.
Instead of trying to figure out each others secrets..
Last post March 14, 2011, 09:32:27 PM
by axman
Last post March 20, 2012, 02:15:33 PM
by Gattlin
Last post August 03, 2012, 12:48:54 PM
by Jim Jack
Last post October 13, 2012, 09:39:03 AM
by Rickard
Last post January 17, 2013, 12:03:06 PM
Last post April 15, 2013, 11:16:04 AM
by snowman48047
Last post May 22, 2014, 12:54:50 PM
by ITGEEK
Last post June 25, 2014, 03:24:11 PM
by ITGEEK
