Author Topic: contour lines on lake map fading in and out  (Read 14339 times)
Offline whistle Pig
« on: August 23, 2011, 12:21:32 PM »
I have a 1198c si, and i am using a navionics platium map card.  On my last trip the countour lines on the lake map kept fading in and out,  a blank outline of the map would remain on the screen.  Anyone have any suggestions as to what might be wrong.   I updated my unit with the 5.70 just before going out.
Re: contour lines on lake map fading in and out
« Reply #1 on: August 23, 2011, 01:30:36 PM »
Was it doing it before you updated?
Offline whistle Pig
« Reply #2 on: August 23, 2011, 08:56:45 PM »
no problems before the update,  but i did have a navionics map card inserted at the same time i did the update,  would that effect the update
« Reply #3 on: August 23, 2011, 09:12:49 PM »
It shouldn't, but they do recommend you remove all cards when doing the updates.
Do you have the Navionics card in when this happens?  Does it happen when its out?
If the Navionics card has nothing to do with it, I would probably go back to the previous update, see if it happens.  Then reinstall 5.700 and see if it happens.  (Make sure you dont have the Navionics card in when doing the update)
Good Luck,
Offline whistle Pig
« Reply #4 on: August 24, 2011, 12:21:15 PM »
OK, thanks robert,  ill try that,  i wont be able to get back out until Friday
Offline whistle Pig
« Reply #5 on: August 25, 2011, 12:16:24 AM »
Robert, can you tell me where i can find a site that i can download the 5.410 update, i have searched and searched but cannot find a site to download it.  Its no longer on my humminbird account list.
« Reply #6 on: August 25, 2011, 04:25:49 AM »
 ;) We are the only site to keep all the prior Downloads!
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=22
Good Luck,
« Reply #7 on: August 25, 2011, 11:18:50 AM »
To add to Robert's with the qujick link....at the top of the main forum page is a tab called Downloads.  You can
access this by cvlicking on the tab.  Then select yhour unit and look for stored downloads. chose the one you want.
Of course remember to restore factory defaults before loading any code..
Chuckj
Offline whistle Pig
« Reply #8 on: August 25, 2011, 06:30:40 PM »
As i look at the list of the downloads, i see the 5.500 on there also,  which i have not done,  would it be ok if i were to update my unit with all three (5.410, 5.500, and 5.700) in succession
« Reply #9 on: August 25, 2011, 07:36:27 PM »
Not necassary, but it could be done.  Each update will contain all the priors before it.  So if you go from 5.410 to 5.700, it will enable the feature or updates that were included in 5.500.  Just backdate to 5.410 or 5.500 and see if you get the same issue.
Offline whistle Pig
« Reply #10 on: August 25, 2011, 07:48:39 PM »
k, thanks robert,   ill see if i can get you a raise.   I appreciate youre help so much
Offline whistle Pig
« Reply #11 on: August 26, 2011, 08:13:29 PM »
I went out today (Friday)l. I did the 5.500 update, the problem was still there but the frequency was not as bad,  when it first began it would fade in and out about every 15 to 20 seconds.  Today it would do about every 45 seconds.  No problems at all when i was not on plane.   I tried it with the settings on factory default,  no difference.  I then did the 5.700 update.   No change.
Last post September 02, 2015, 02:54:20 PM
by lolar3288
Last post March 01, 2011, 09:06:24 PM
by noisemaker
Last post July 02, 2011, 05:10:34 PM
Last post June 07, 2012, 02:20:38 PM
by rlazop2004
Last post July 03, 2012, 09:41:27 PM
by bomac
Last post April 07, 2013, 06:21:52 PM
by RuffWood
Last post May 26, 2019, 10:29:30 PM
Last post April 02, 2022, 08:40:30 PM
