Author Topic: Help choosing shoot thru  (Read 7409 times)
Offline Goingbig
« on: August 20, 2011, 11:09:45 AM »
  Hey everyone I have had my 998 Si for a little over a year and I have loved it!  I currently am using it paired with two transom mount transducers (xhs 9 hdsi 180).  Only thing I have had problems with is getting high speed bottom readings.  This is expected with transom transducers.  I have recently been debating using a AS SI DB Y paired with a shoot thru for the 2d at high speed.  My question is basically which shoot thru would you suggest?  I fish saltwater out to about 150ft.  I was looking for forum post reguarding shoot thru transducers and saltwater results and couldnt really find anything.  Anyone out there use it?
Offline Roddy
  • Scan,scan and rescan
Re: Help choosing shoot thru
« Reply #1 on: August 21, 2011, 12:14:37 AM »
Goingbig; SI does not work as a shoot thru hull (in hull)install.
You may try a thru hull with a HB XTH 9 DB 35 KW T or a XPTH 9 HDSI 180 T, big hole in the bottom being a thru hull.
If the boat hull is single layer (not multilayer) a in hull may work but may have diminished returns in 2d. SI will not work!!!!
Hope this helps a little.  Roddy
Scan,Scan and Rescan Roddy
Offline bearpeter1
  • Unit(s): 998 SI
  • Software: latest
  • Accessories: humviever
« Reply #2 on: August 22, 2011, 12:05:11 AM »
big, I have the standard transducer plus the AS SI DB Y,needed a 2'' holesaw thru the hull. lucky my bilge is only about the size of a bread box.
peter.
Last post March 25, 2010, 09:41:57 AM
Last post May 03, 2011, 01:35:10 AM
by LocDown
Last post August 21, 2012, 01:30:39 PM
Last post September 12, 2014, 09:58:18 AM
Last post March 20, 2016, 11:11:47 PM
Last post February 19, 2017, 06:08:06 PM
by 362 ranger pilot
Last post April 24, 2016, 11:12:27 AM
Last post September 24, 2017, 10:00:42 PM
