Author Topic: Upgrading Humminbird PC Question  (Read 14052 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
« on: August 12, 2011, 04:29:12 PM »
I have V3.2.2 in my computer and my profile shows an upgrade available V4.1.1. I have read somewhere that I should uninstall the old version before downloading the new is this true? If it is I would have to copy all my wpts, tracks, rtes to an SD card and then reload them when the new version is installed, correct?
I see I also need to upgrade the software in my 788ci and 998si. Little leery about that.
Re: Upgrading Humminbird PC Question
« Reply #1 on: August 12, 2011, 08:04:48 PM »
Might consider keeping the old rev.  Greg has mentioned that the older rev's can import and export .txt files while the new version currently cannot.
If you have the luxury of 2 computers you could have a different version on each......I don't know if you can have both rev's on the same computer or not.  Maybe someone else can answer that.
Offline 6speedy3
« Reply #2 on: August 13, 2011, 10:40:15 AM »
Thanks Bob, I think I will take that advice, unless Greg or someone has another idea to think about.
« Reply #3 on: August 13, 2011, 04:08:08 PM »
I went back and looked at Greg's post again, and I may have misinformed you.  He said he uses 2.5.8 for the .txt files.
Greg will probably be back in here on Monday and can clear that up for you.
Offline 6speedy3
« Reply #4 on: August 13, 2011, 04:30:54 PM »
Thanks Bob, I will hold off. :) :)
« Reply #5 on: August 16, 2011, 09:21:24 AM »
Bob is right: the 2.5.8 version has the *.txt file import capability that the newer versions do not have.
I don’t think that you have to uninstall the previous version of HumminbirdPC when you are upgrading.  I usually just perform the upgrade without uninstalling the last version – unless I am going back to an older version to test something.  Than I uninstall the current version.
By the way, you can run the 2.5.8 version on your PC at the same time that you are running the newer version or at least I can on my Windows XP machine.
Offline 6speedy3
« Reply #6 on: August 16, 2011, 10:34:51 AM »
So it would be a whole additional program, it doesn't just overwrite the old version? I have V3.2.2, so it probably doesn't import .txt files anyway?
« Last Edit: August 16, 2011, 10:37:30 AM by 6speedy3 »
« Reply #7 on: August 16, 2011, 10:37:25 AM »
That is my understanding that it completely replaces the old file and does not go into the old and change things..
Chuck.
Offline 6speedy3
« Reply #8 on: August 16, 2011, 10:42:05 AM »
So, then I have to transfer all my waypoints etc from V3.2.2 to the upgraded version?
« Reply #9 on: August 16, 2011, 10:44:50 AM »
I think so.  Which is why we want to make backups before upgrading...
« Reply #10 on: August 16, 2011, 02:13:19 PM »
The waypoints are not saved within the programming of HumminbirdPC.  They are saved in a location on your computer’s hard drive.  All you would have to do is ‘point’ the newer version of HumminbirdPC to that location.
Just go ahead and install the newer 4.1.1 version and than go into the Add/Remove Programs function of your computer and see if it lists more than one version of HumminbirdPC and delete the one(s) that you do not want.
Offline 6speedy3
« Reply #11 on: August 16, 2011, 06:02:43 PM »
Thanks Greg.
Last post April 04, 2011, 06:06:41 PM
Last post January 11, 2013, 01:58:09 PM
Last post March 12, 2013, 11:48:11 AM
Last post August 12, 2015, 08:19:14 PM
Last post April 11, 2016, 10:35:39 PM
Last post July 29, 2016, 05:50:43 PM
by afaust
Last post March 06, 2018, 11:33:05 AM
by Major Mark
Last post January 08, 2024, 07:28:00 PM
