Author Topic: Navionics PC waypoints to 898.  (Read 9630 times)
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« on: August 11, 2011, 09:43:08 AM »
Just playing around with the Navionics pc app with the platinum east card. How can I get the waypoints created on pc to the unit? I have exported to a sd card but the 898 doesnt seem to reconize the format.
Re: Navionics PC waypoints to 898.
« Reply #1 on: August 11, 2011, 10:56:46 AM »
I don’t have this program.  What file format options do you have when coping or exporting the waypoint data?
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #2 on: August 11, 2011, 11:05:04 AM »
The file will export as a HWR but the unit does not display the waypoints.
« Reply #3 on: August 11, 2011, 11:14:29 AM »
When you copied the *.hwr file to the SD memory card, did you place it in the MATRIX folder that should also be on the SD memory card?  This is where the unit will look for the *.hwr file at.
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #4 on: August 11, 2011, 12:12:55 PM »
The only folder on the card is Record and Snapshot. Should it be in one of those?
« Reply #5 on: August 11, 2011, 12:22:04 PM »
Look in the record folder.  or when you open the card use the all files selection..  chuck
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #6 on: August 11, 2011, 12:54:31 PM »
No Matrix folder to be found.
« Reply #7 on: August 12, 2011, 02:32:59 PM »
Install the SD card into your unit and power it up.  Go to the Nav menu tab and scroll down to Export All Nav Data and use the Right Arrow key to use this function.  Take the SD card out and install in your computer.  Navigate the SD card and delete the DAT.HWR file that is in the Matrix folder, than copy the *hwr file that you made with the Navionics program to the Matrix folder.  Power your unit back up and install the memory card in it and see if it will upload the waypoints now.
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #8 on: August 12, 2011, 02:36:31 PM »
Thanks I will give that a try.
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #9 on: August 17, 2011, 12:27:55 PM »
Greg, that worked! Thanks
Offline PeterH
    • GPS Chart Plotter PC based
  • Unit(s): 788cx
  • Software: 5.840
  • Accessories: non
« Reply #10 on: October 08, 2011, 07:46:43 PM »
Hi, If I Export Kmz under Routes the Humminbird 788cx will not pick this route up on my SD card?
Why not I wonder?
Please help to get this working.
Thanks.
Peter
Offline crazyju
  • Unit(s): 898c si
  • Software: 5.5
« Reply #11 on: October 10, 2011, 09:47:42 AM »
You will have to export as a hWr file and put it into the DATA file
« Reply #12 on: October 10, 2011, 10:50:52 AM »
The Humminbird units will not recognize the kmz file format.  You will need to either save it as a DATA.hwr file or as a *.gpx file format.  If those are not options than see if you can use another program to convert to either of these file formats.
Last post May 20, 2009, 03:15:58 PM
by inshorecatch
Last post September 21, 2009, 01:11:10 PM
Last post April 04, 2010, 07:31:41 AM
by Jolly Roger
Last post August 04, 2010, 01:50:47 PM
by The Country Toad
Waypoints
Started by Rev 798c SI
Last post March 06, 2011, 06:38:31 PM
by Ddorriety
Last post March 09, 2011, 07:49:30 PM
by Hollywood
Last post May 13, 2011, 11:35:52 AM
Last post June 05, 2014, 12:49:02 AM
by LittleGazoo
