Author Topic: 997 GPS  (Read 3640 times)
Offline larryb
  • Unit(s): 997NVB
997 GPS
« on: April 17, 2011, 02:52:47 AM »
Iam having alot of problems with my 997 NVB picking up a signal. What is going on with this? This unit has 466hrs of use on it. This is the 6th time it has done this.
Re: 997 GPS
« Reply #1 on: April 17, 2011, 10:36:51 AM »
Where is the antenna mounted?  Could something be obstructing the signal?  Did something change in your boat to cause an obstruction...?
« Last Edit: April 21, 2011, 04:16:37 PM by sonar2000 »
Offline larryb
  • Unit(s): 997NVB
Re: 997 GPS
« Reply #2 on: April 20, 2011, 10:38:22 PM »
Its mounted on the rear of my boat. I can tap on it sometimes and it will work fine.Its been a problem ever since I have bought unit. I like the unit alot, just wish GPS worked the times i find structure to fish----want to mark them.
Re: 997 GPS
« Reply #3 on: April 21, 2011, 04:16:15 PM »
Sounds like a bad puck.  do you have someone you can try your unit with another antenna....
