Author Topic: sidi imaging and sonar stopping  (Read 5983 times)
Offline dgreenhill
  • Unit(s): 2
  • Software: 5.2
« on: April 14, 2011, 10:32:22 PM »
My 898 is about 3 months old the screen freezes.The map doesn't just  sonar and si. the depth read out goes nuts also. Any help?
Offline dvanpham
  • Unit(s): 798ci SI and 998c SI
  • Software: 6.180
  • Accessories: Interlink, DrDepth
Re: sidi imaging and sonar stopping
« Reply #1 on: April 15, 2011, 10:39:15 PM »
This helped me and another person on this forum with a similar problem.  It was originally posted here - http://forums.sideimagingsoft.com/index.php?topic=2377.msg13059#msg13059
I don't know if this will work for you or not, but it worked for me on both my 998c SI and 798c SI with a similar problem - mine was locking up and acting sporatically on certain screens until I did this with my units:
1)  I adjusted the power plug pins with a small screwdriver to make sure it's seated in the Humminbird unit with a solid connection.  If they're too straight, these problems would present themselves.
2)  Make sure any SD cards you have in the unit are blank or removed unless you need them.  I found with mine that if I had an SD in my unit, it make it act very strangely.  Once I backed them out or cleared them out, that my units ran much better.
Hope this helps.
Last post January 01, 2010, 06:37:51 PM
by Teamleader
Last post April 21, 2010, 10:06:39 AM
by mendota
Last post December 26, 2011, 01:27:25 AM
by Roddy
Last post February 24, 2012, 01:42:20 PM
Last post October 26, 2012, 12:52:57 PM
by Roddy
Last post December 18, 2013, 03:14:52 PM
