Author Topic: 5.410 vs 5.210  (Read 6794 times)
Offline casey1979
  • Unit(s): 1197 958c
  • Software: 5.430
  • Accessories: interlink
5.410 vs 5.210
« on: April 14, 2011, 12:38:27 PM »
whats the difference between these two softwares?    thanks   kc
Re: 5.410 vs 5.210
« Reply #1 on: April 14, 2011, 04:17:35 PM »
Which unit we talking about here kc?
Offline dustlane
  • Unit(s): 898si
  • Software: 5.410
Re: 5.410 vs 5.210
« Reply #2 on: May 08, 2011, 09:39:11 PM »
I would stick with the 5.210 if I were you. I did the update and now my screen flashes when I try to switch views, and a minute ago, it just shut down and restarted twice for no reason while I was changing views.  I need a copy of the older 5.210 software for my 898 if you know of a place I can get it. I have a tournament coming up this weekend and I really need to get this 5.410 "update" off of my unit before I go. Thanks!
Re: 5.410 vs 5.210
« Reply #3 on: May 09, 2011, 11:38:20 AM »
dustlane,
You should be able to find the 5.210 software for the 898 unit on this web site.  Look here:
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=1
Do you have your 898 connected with another unit?
Have you recently loaded any waypoints from another brand unit or from a program such as GPSBabel?
Offline tambrose76
  • USMC Ret.
  • Unit(s): 898c, 737, WIDE ONE, SUPERTRAP30, PORTAB
  • Software: ALWAYS UPDATED
  • Accessories: GPS16 WXSENSE
Re: 5.410 vs 5.210
« Reply #4 on: June 23, 2011, 11:10:05 AM »
Using 210 and Lakemaster WI 1.0.2 with Countour Elite. Warm-boots while switching views, esp. trying to get back to the Chart on my 898 now occurs after a perfectly good operating unit was impacted by an SD card that had a "matrix" folder update that contained new hwr and ht files imported from Contour Elite software. WI Lake chip was left installed, per CE directions, and defaults were not set as a result. New waypoints and routes imported fine during the update but after about ten strokes on the View or Exit keys, restart occurs without loss of panel lighting (warm-boot). I noticed that any previous actions of menu selection are disengaged after warm boot; if I turned off a view, it was back on after the reboot. New files in matrix were the only change--six of them--named properly.
"Some men see things as they are and say why.
I dream things that never were and say why not." --George Bernard Shaw
Re: 5.410 vs 5.210
« Reply #5 on: June 23, 2011, 01:35:19 PM »
tambrose76,
First thing I would do is update the software in your unit to the current 5.500 software.  If that does not help than try deleting the data you imported from the Contour Elite program and see if it straightens up or not.  I have heard a few reports of tracks and routes imported from this program causing problems with our units.
