Author Topic: Software Version 5.2  (Read 13636 times)
Offline Fishfor5
  • Unit(s): (2) 898 SI
« on: February 03, 2011, 09:30:35 PM »
If I understand correctly the new software version will fix the shallow water problem.  My unit currently does not read very well in depths of 5' or less.
I have to 898 units interlinked.  I can't remember what version of software I have but I do know when I bought my units the interlink did not work very well.  Humminbird sent me a new version of software that was still being beta tested and wasn't out yet, therefore, I don't remember the version.  Since I installed the beta version the units work great except in shallow water.  Should I install the 5.2 version?  I'm sort of afraid of messing them up.
Thanks,
Re: Software Version 5.2
« Reply #1 on: February 03, 2011, 10:31:41 PM »
Fishfor5,
Check your software version and definitely let us know what installed.  You can do this by pressing the Menu button when prompted at startup and checking the system status.
I would say probably go ahead and do it.  I have not heard of really any issues with updates since humminbird fixed the issue with the last update.  Just follow the directions posted in the FAQ section.
Offline jules2003
  • Unit(s): 898c SI
  • Software: 6.420
« Reply #2 on: February 06, 2011, 01:04:43 PM »
I installed the Version 5.210 on my 898 last week. I  tried the new version on the Rhein and I have still problems with depth reading in shallow water less than 5´. My old version was 4.880 and I restored defaults before I was updating.
Any ideas ?
Regards Michael
« Reply #3 on: February 06, 2011, 01:14:34 PM »
Is the trouble with the depth not reading right or is the display not showing the bottom correctly as in the type and structure of the bottom?
Offline jules2003
  • Unit(s): 898c SI
  • Software: 6.420
« Reply #4 on: February 07, 2011, 01:22:33 AM »
The trouble with the depth not reading is right. In less than 5`water depth the unit depth is about 1`. When the water depth is more than 5´, the depth reading is correct. I set the max. depth to 45`in 30´deep water. I had the same problem with software 4.970, so I installed 4.880 again. With the original software I have no problems with depth reading.
Regards Michael
Offline Fishfor5
« Reply #5 on: February 07, 2011, 09:42:30 AM »
Chuck,
The depth just starts acting crazy and the bottom doesn't read at all.
Michael,
My units came with 4.880 and I noticed the same problem with that version as well.  I personally can't go back to that because that is what was causing my interlink problems.  The reason I am a little reluctant to change versions of software is because my units work great other than the shallow readings.
« Reply #6 on: February 07, 2011, 01:19:02 PM »
Shallow depths can be somewhat challenging, but our 1197 does not have any problems with 2 or 3 feet...
Sounds like some more software testing is necessary for HB......
Last post January 31, 2015, 12:55:13 PM
Last post January 19, 2015, 04:53:02 AM
by sfw1960
Last post December 26, 2016, 07:34:48 PM
Last post April 02, 2017, 10:29:05 PM
Last post April 26, 2019, 11:49:40 PM
Last post May 23, 2019, 10:20:30 PM
Last post May 23, 2019, 10:22:16 PM
Last post July 28, 2022, 03:46:11 PM
by Davide
