Author Topic: need help  (Read 5604 times)
Offline smoke20
  • Unit(s): humminbird 898c si combo
need help
« on: September 26, 2010, 10:30:32 PM »
I have a 898c Si combo the three times I have been out  the gps only shows have of the lake  i am on  the first time  I was at  Priest lake in northern Idaho
N 48  30.987  W 116  53.228  and it only showes half of the lake   and this last week I was on the Columbia river  in Wash. state   N46  52.617  W 119 57.847  and It would not show any of the river  it would just  leave a trail  on a brown back ground  I have try the zoom in and out and nothing . Do I not have something not set wright and I can not find the contour XD  can some one help  Thanks
Offline George
  • Software: Always up todate
Re: need help
« Reply #1 on: September 28, 2010, 07:18:58 PM »
Smoke20
I cannot say for sure, but checking my 1197 NVB and Navionics Hotmaps Explorer program I do not see that Navionics has charted out your lake.
I do not have any Navionics cards covering your area, you might want to call Navionics to see if they cover your lake.
I do not believe that they are charting rivers especially since rivers are very dynamic with depths changing frequently.
You may want to purchase Navionics Hotmaps Explorer for $19.00 to view the lakes in your area ( Priest lake is not covered).
Hey guys please correct me if I am wrong.
George
Offline smoke20
Re: need help
« Reply #2 on: September 28, 2010, 10:04:25 PM »
Thanks for getting back to me  so if I do not have a card in the unit  it will not show any lakes is that wright , so the unit has no lakes in it from the fac.  so the only way to use the contour xd is with a navionics card  is that wright . so when I go out to a lake  it is not going to show that there is a lake there unless I have a card in it  its not like a gps in a car that showes everything  thanks ???
Re: need help
« Reply #3 on: September 29, 2010, 04:36:08 PM »
Contour XD is the current base map we are installing in the 898c Si units (it took the place of the UniMap we used as a base map before).  Some of the Contour XD maps do have depth contour lines on them although not at the same level as a Premium HotMaps or LakeMaster mapping card will have.  If the lake you are on is covered by the Contour XD base map than it will be shown, if not it will show it as land unless you have purchased and installed a map card that has this data on it.
Offline George
Re: need help
« Reply #4 on: October 06, 2010, 11:50:55 AM »
As Greg pretty much stated is all HB SI units have Contour XD installed as a minimum.
My unit is a NVB unit and I have not viewed the new Contour XD maps.
Again not sure if the lakes you use are covered by Navionics, you might want to check with them.
If you post the lakes you fish I will try to check on them for you.  Somewhere Navionics posts which lakes are covered.
George
Wayne P.
  • Guest
Re: need help
« Reply #5 on: October 06, 2010, 12:32:50 PM »
The list of waters with Contour XD is on this site in the software download section.
http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=32
Offline George
Re: need help
« Reply #6 on: October 06, 2010, 02:34:13 PM »
Smoke20
Contour XD have 17 lakes listed for Idaho and the Navionics Chip have 49 lakes listed.
Below is the list I found opening Wayne's post and on Navionics site for the 2010 chips.
Hope this helps
Idaho (17)
Anderson Ranch Reservoir Elmore ID
Arrowrock Reservoir Elmore ID
Bear Bear Lake ID
Blackfoot Reservoir Bingham, Caribou ID
C J Strike Reservoir Elmore ID
Cascade Reservoir Valley ID
Coeur d'Alene Kootenai ID
Daniels Reservoir Oneida ID
Dworshak Reservoir Clearwater ID
Lucky Peak Boise, Elmore, Ada ID
Mackay Reservoir Custer ID
Mann Creek Reservoir Washington ID
Montpelier Reservoir Bear Lake ID
Palisades Reservoir Bonneville ID
Pend Oreille Bonner, Kootenai ID
Redfish Custer ID
Ririe Reservoir Bonneville ID
Idaho (49)
Alturas   Blaine     ID
Bear         Bear Lake (ID) Rich (UT)  ID
Belvidere       CreekValley  ID
Cache Creek Lakes   Lemhi   ID
Copper Shoshone ID
EchoIdaho ID
Elizabeth Clearwater ID
Ellie Clearwater ID
Fernan Kootenai ID
Fish Clearwater ID
Gold Shoshone ID
Heathe Shoshone ID
Ice Clearwater ID
JackClearwaterID
Lucky Peak Boise
Elmore, Ada ID
Mann Nez Perce ID
Mush Clearwater ID
Palisades Reservoir Bonneville (ID), Lincoln (WY) ID
Payette Valley ID
Pend Oreille    Bonner Kootenai ID
Pete Ott ClearwaterID
Pettit   Blaine ID
Pot    Clearwater  ID
Redfish Custer ID
Silver Shoshone ID
Snowy Top Boundary ID
Soldiers Meadow Reservoir Shoshone ID
Spring Hill Reservoir   Latah ID
Stanley Custer ID
Steep (Lower)  Clearwater ID
Steep (Upper)  Clearwater  ID
Tille Clearwater ID
Tin Shoshone ID
Waha  Nez Perce ID
Williams Lemhi ID
Yellow Belly Custer ID
George
« Last Edit: October 06, 2010, 02:40:16 PM by George »
