Author Topic: Waypionts from PC to 898SI  (Read 6938 times)
Offline squeezethesnake
  • Unit(s): 898 SI
« on: September 04, 2010, 11:29:20 AM »
I have been working on adding new waypoints on my PC with Humminbird PC Program and when I insert the card with all my new points the 898 it displays loading but the only points i Have are the ones that were already there. I have 71 waypoints on my card ( the ones I uploaded from the unit and then added more) but I see I only have 47 the same number I had before adding the new ones. I looked on the manual and seems I am doing right but I know I am missing something. any advise
thanks eric
Wayne P.
  • Guest
Re: Waypionts from PC to 898SI
« Reply #1 on: September 04, 2010, 12:05:24 PM »
Did you select the correct folder in HB PC to load to your SD card?
  • Unit(s): 898 SI
« Reply #2 on: September 04, 2010, 12:13:11 PM »
I dragged and dropped from PC waypoints Folder to Card waypoints folder and checked both and both had all the points
« Reply #3 on: September 10, 2010, 04:25:55 PM »
The waypoints have to be converted to the DATA.HWR file format before the 898 will recognize and load them.  To do this you have to use the upload feature in HumminbirdPC the get the waypoints from HumminbirdPC to the SD card.
Last post March 05, 2010, 11:16:58 PM
by Stymie
Last post June 26, 2010, 11:53:43 AM
by JeffA
Last post June 30, 2010, 03:46:07 AM
by TazzMan
Last post July 14, 2010, 08:50:35 PM
by RzorbackAngler
Last post October 22, 2010, 10:35:35 AM
Last post November 13, 2010, 12:42:58 PM
Last post April 28, 2016, 01:35:06 AM
Last post August 04, 2016, 09:18:39 AM
by larry crouch
