Author Topic: 798 Ci Down Imaging Problem  (Read 7628 times)
Offline BIGEYEZ
  • Unit(s): 798ci SI
« on: August 30, 2010, 08:35:39 AM »
Since I installed the latest upgrade, My down imaging (DI) screen shows some type of interference.  Side imaging and 2D sonar work fine, but the down imaging screen is solid interference.  If I change from some other view to down imaging, it show the recent past fine, but instantly after switching to DI view, the screen clutters?  I took a snap shot this weekend, but haven't removed the SD card to put upload it to my PC.  My unit is set up to be portable and can be used on a trolling motor or transom mounted.  I have not used the unit on a trolling motor since I installed the update but have used it on two different boats and DI screen did the same on both.  Any ideas.  Thanks.
Offline Kenosha
  • Unit(s): HB 898
Re: 798 Ci Down Imaging Problem
« Reply #1 on: September 04, 2010, 09:12:37 AM »
Check to see if the bottom lock is turned on.
Last post July 25, 2009, 02:24:11 PM
Last post December 18, 2009, 03:24:41 AM
by IRC Kevin
Last post August 29, 2012, 10:51:48 AM
Last post March 21, 2011, 08:18:37 PM
by sss_floripa
Last post June 28, 2012, 12:00:14 AM
by Roddy
Last post April 22, 2014, 08:24:53 PM
Last post June 10, 2014, 04:49:58 AM
by Skymaster
Last post January 19, 2017, 11:13:58 PM
