Author Topic: Screen Cleaner  (Read 9965 times)
Offline tennwalkinghorse
  • Unit(s): 898cSI
  • Software: 6.420
Screen Cleaner
« on: August 06, 2010, 09:13:10 PM »
What do most of you us to clean your screen on your units? I ask because so cleaners leave a film.
Re: Screen Cleaner
« Reply #1 on: August 06, 2010, 09:29:40 PM »
Check here in the FAQ section.
Quote
Humminbird recommends using Windex® Vinegar Multi Surface(in the spray bottle).
Do NOT use any wipes products (which can also be available as the brand name Windex Multi-Task).
The lens contains a special coating which improves visibility.  It is recommend to use the above cleaner because we have tested and proved this cleaner.  It does not deteriorate the coatings on the lens.
http://forums.sideimagingsoft.com/index.php?topic=1038.0
Re: Screen Cleaner
« Reply #2 on: August 07, 2010, 09:40:51 PM »
It sounds nasty but I use a microfiber cloth and and a little saliva...
Offline Deltaden
Re: Screen Cleaner
« Reply #3 on: August 09, 2010, 03:09:33 PM »
I found that certain brands of paper towel leave streaks.  The best in my opinion is Bounty.  Stay away from Viva (I think it's "treated").
Fold one sheet to about the size of the screen and get the towel wet with many drops of the recommended Windex and wipe sideways once.  I let the screen "air dry".  Don't use a dry sheet, it leaves a film.  I just wipe across with the very wet towel and let it dry by itself.  I only takes a second or two.  Just my opinion.  Others, please join in.
Thanks.
Wayne P.
  • Guest
Re: Screen Cleaner
« Reply #4 on: August 09, 2010, 04:05:47 PM »
I only use a micro fiber cloth and Vinegar Windex on my screens. Any paper product can scratch the screen/coating.
Re: Screen Cleaner
« Reply #5 on: August 09, 2010, 06:43:51 PM »
I have found that by putting a screen protector on that doesn't show finger prints has been a huge help!  Screenpatronus is a dealer on ebay and they have some of the least expensive.
I also try to use a micro-fiber cloth when cleaning.
Re: Screen Cleaner
« Reply #6 on: August 11, 2010, 02:39:54 PM »
I also use the Screenpatronus that Robert mentioned...very easy to install and much cheaper than some of the other brands....
I think it was something like $12.99 plus shipping....for the 1197 protector
Last post January 03, 2010, 10:10:38 PM
by HawgTyme
Last post April 17, 2014, 03:23:07 PM
Last post June 10, 2015, 01:05:26 PM
Last post July 12, 2015, 10:32:00 PM
Last post April 21, 2017, 04:10:22 PM
by Reelcrazy
Last post August 12, 2019, 10:14:48 PM
Last post October 29, 2020, 07:01:29 PM
