Author Topic: Lost my chart function.  (Read 14050 times)
Offline equinox
  • Unit(s): 997 C
« on: July 16, 2010, 02:32:18 AM »
After my update 4.950 all was working. When I started the unit 2 days later the chartfunction was missing, now 3 days and several attempts to restart the unit later it still doen´t start.
I have tried to reset defaults and tried to put the SD card with the chart in the other reader with no respons. If I put in the SD card I used for the update it tells me the unit is already updated, but it doesn´t react when I insert the chart card.
Re: Lost my chart function.
« Reply #1 on: July 16, 2010, 02:37:03 AM »
equinox,
Welcome to the forum.  When you say lost your chart function, if you have no chart card installed, can you see the Chart View with the base map?
Is your GPS reciever connected?  You will not be able to see the Chart Views if your GPS is not connected or has come loose.  Check your connections and see what happens.
Offline equinox
  • Unit(s): 997 C
« Reply #2 on: July 16, 2010, 02:55:07 AM »
Ok.
I will check my antenna connection, the base map is also missing.
Thanks for the quick reply.
Last post February 10, 2011, 10:44:25 AM
by The bird
Last post June 04, 2011, 10:54:46 PM
by bigbass
Last post February 23, 2013, 10:33:35 PM
by busterboy2238
Last post December 26, 2013, 01:49:58 PM
Last post May 12, 2014, 12:11:13 PM
by Ronny
Last post May 13, 2014, 11:13:40 AM
by billius
Last post July 09, 2015, 11:24:06 AM
by Carver
Last post February 04, 2020, 09:46:17 PM
