Author Topic: Ok Need Help..  (Read 9422 times)
Offline jseasor
  • Trying to learn as much as possible about SI
  • Unit(s): 1197C SI
  • Accessories: 1197SI
Ok Need Help..
« on: May 03, 2010, 08:11:25 PM »
went out today on the lake, i took several pictures..nothing major. but i have a couple good videos that i would like to host on here or be able to send them to a buddy of mine. what is the best way to convert my file. i have the son2xtf program but i cant get my videos to work on the SI program.  i would like to be able to store this videos on my computer for me to review at anytime, delete from my card and be ready to go again. what are my easiest options? thanks!
PS i also have YellowFin, but im clueless...
« Last Edit: May 03, 2010, 08:36:47 PM by jseasor »
Re: Ok Need Help..
« Reply #1 on: May 04, 2010, 08:08:44 AM »
Are you talking video or recordings?  Are you trying to get the recording into the pc to make a video?
Humviewer will play back a recording and you can send this to other folks.
Let us know exactly what you are trying to do.
Offline Chiboo
  • SpearFishing
  • Unit(s): Solix 10 MSI+ G3
  • Software: 4.130
Re: Ok Need Help..
« Reply #2 on: May 04, 2010, 08:28:23 AM »
Data with Flash can be copied or transferred (having released a place) on PC as is with preservation of structure of folders and further to look them in HummView and i.e.  As it is possible to copy back the data on Flash and to look at Fishfinder. For example, I look data on 1197 written down on 797.
Offline jseasor
  • Unit(s): 1197C SI
Re: Ok Need Help..
« Reply #3 on: May 04, 2010, 03:58:16 PM »
yes i want to be able to take a recording and send it to a buddy of mine so it'll play on his computer. keep in mind, he doesnt have humviewer or yellowfin.  i still can't get humviewer to load on my computer and its really ticking me off!!!! >:(
Re: Ok Need Help..
« Reply #4 on: May 04, 2010, 04:10:07 PM »
OK for the recording  you start the recording on your unit and it will put the data on the sd card you have in the slot.  once on the card you can copy to your computer.  Once there you can do a lot with it.
And when humviewer is running it is no end to the limits.
Not sure about the error your are getting on the install.  I have humviewer running on vista. Maybe harry or one of the computer gurus can get a handle on it.
If Robert gets on he will probably have the fix.
I will check around a bit.
Re: Ok Need Help..
« Reply #5 on: May 04, 2010, 04:19:27 PM »
Another thought.......have you downloaded the latest java update?  You might have to update that first.   Humviewer may run in 64 bit mode on vista.  so try running a java update.
chuck
Offline jseasor
  • Unit(s): 1197C SI
Re: Ok Need Help..
« Reply #6 on: May 04, 2010, 04:32:46 PM »
ok, i finally got the humviewer working....gonna take some time to get use to it.  now in order to get the DI to work i have to change it to quadrabeam? correct. secondly, in the bottom left hand corner it shows a boat as i guess its tracking my position. but it shows nothing but a boat and a colored line.  should there be a map? also, i have google earth 5 and i can't get the two to work correspondily...man im so confused..
still dont understand how anyone can just view my SI video from my chip.  from what i read are you saving that it works on anything? i can't get it too, only if i have the humviewer open does it work. boy i thought i was computer savy.....guess not
also what program are you guys using to view your snapshots? humviewer will not open mine
« Last Edit: May 04, 2010, 04:37:38 PM by jseasor »
Re: Ok Need Help..
« Reply #7 on: May 04, 2010, 04:48:24 PM »
OK on humview.  make sure you are on version 67.
DI uses the HDSI selection.
To start the playback click on the play box.  to stop click the box again.
 On the humview screen look at the top left and click on the box to select the view.  by the grid and wayp.  select the upper left view...  once that is up right click on the screen and select view.  then select down imaging.  DI  not the 2d.  This will get you the DI display.
If you have selected 3 view you will see in the lower left corner the boat track from your recording. no map just a track.    and the right will be the SI.
Recording on the sd makes thre data available to anyone who has a reader and a program. (humviewer, Yellowfin, SIview, Deepview  to name a few.)
 In humview you can make a movie ftrom the recording.  Anyone can then view the movie with a standard computer movie viewer.
OK.  where are we now?   let me know.
Offline jseasor
  • Unit(s): 1197C SI
Re: Ok Need Help..
« Reply #8 on: May 04, 2010, 06:00:36 PM »
got it working man, i appreciate the help!!! now how does the waypoint work.
this may be a dumb question, but other than viewing and watching your recordings. what are the advantages of having the humviewer?  i go the movie thing working..thanks! last thing, how come every now and then when im viewing the recording, its not a full screen, its like parts of it didn't transfer, its real weird..
Re: Ok Need Help..
« Reply #9 on: May 04, 2010, 06:30:35 PM »
OK.  good deal.   ;D ;D
Waypoints I will leave for someone else as I dont use them...
Viewing programs on external viewers give you:
1) a larger screen
2) Better color
3) More ability to move around in the recording
4) Better color enhancements
5) Better zoom
6) Better target location or relocation
7) Better depth definition
8) Better screen captures without clogging up your unit or being able to take a scren capture with out stopping the recording process on the unit.
9) For search and recovery a better look at the target.
10)  makes you a pc Geek.  ;D ;D  Just kidding.  needed a 10th item.
Partial screen display is the way the program handles depth  or depth changes.  not really a problem.  It catches up.
Whew.  Keep asking.  I need the typing experience.   ::)
glad to have you here and asking.  you will be up and running like a pro very soon.
Next thing you will be posting pictures.
Re: Ok Need Help..
« Reply #10 on: May 04, 2010, 08:36:47 PM »
In the upper right hand corner click the "Utilities" box..under this, click the dropdown arrow.. you will have several options to work with your recording...
Highlight the waypoint feature...then anywhere on your SI screen click a point with your mouse and a waypoint will be created at that exact spot on the recording because all the GPS data from your HB recording is in that recording so the program knows where that exact spot is on the lake by the GPS data ....
When you place your red dot waypoint on the SI screen a box will pop up where you can name the waypoint..
I usually lable mine as R00001b1, R0001b2 ...
   "R00001" represents the recording number asigned by the HB unit..
   "b" represents a brushpile
   "1" represents the first waypoint in track that I marked in the Humviewer program...
After you have all your waypoints marked on the SI screen thru the entire recording.. Then, in the top right, click on "tools" (I think) and then click on waypoint... a box will pop up where it should list every waypoint you marked in the Humviewer program where you can rename,, delete,, etc.
Then under the same "tools" in the upper left click on "Show in Google Earth"
If you have the correct Google Earth installed on your Pc...Google Earth should open to the aerial photograph on the area of the lake that you made the recording and show all the waypoints that you marked in the Humviewer program...
I'm typing this from memory so bear with me...
Offline jseasor
  • Unit(s): 1197C SI
Re: Ok Need Help..
« Reply #11 on: May 04, 2010, 10:43:11 PM »
 ;D Great thanks for the info!!!! im starting to get it slowly but surely. what program are you guys using to clean up your snapshots? just an ordinary photoshop?
secondly, i can't get my google earth to work with my humviewer or even my humminbird program. i have the latest version of it, it works just fine when i click on it, but it wont work with either program. am i missing something here.
sorry for all the questions guys....i really appreciate all the help and patience!
Re: Ok Need Help..
« Reply #12 on: May 04, 2010, 10:44:42 PM »
No, HumView is just not compatible with the latest versions of GE yet.
Re: Ok Need Help..
« Reply #13 on: May 05, 2010, 07:21:42 AM »
To edit snapshots we use Photo-Shop Pro.
Re: Ok Need Help..
« Reply #14 on: May 05, 2010, 07:51:06 AM »
I use Google Earth version 4.2.0205
Get it here....http://www.filehippo.com/download_google_earth/
