Author Topic: Is there a tutorial?  (Read 16452 times)
Offline Dam Yankee
  • Unit(s): Two 798 CI SI NVB
  • Software: 4.780
  • Accessories: Interlink, Weathersense
« on: April 16, 2010, 08:08:02 PM »
I finally made it to the lake and was able to make some recordings of a few areas. Is there a tutorial on everything that is needed and how to install for taking recordings from an SD card to the PC for viewing, marking etc?
I have downloaded Hummviewer and have played the demo file and it is working. I read that I also need yellowfin and from what I understand I also need something else. Maybe I am reading in the wrong place. Gonna keep lookin around.
Tom
« Last Edit: April 16, 2010, 08:10:07 PM by Dam Yankee »
Re: Is there a tutorial?
« Reply #1 on: April 16, 2010, 08:24:58 PM »
Tom,
YellowFin will only play back the SI portion of the recordings, but it has some pretty good features for measuring objects.
If you use YellowFin you will need to download my HBSI Converter to convert the SON files over to the .872 yellowfin format.
As for a tutorial, HumViewer and the HBSI converter have help documents with them.
Good Luck and let us know if you have any other questions.
Offline Dam Yankee
  • Software: 4.780
« Reply #2 on: April 16, 2010, 09:10:45 PM »
From what I am reading I should be able to view with hummviewer. When I click on the sd card there is no file appearing but, it plays on the head unit.
« Reply #3 on: April 16, 2010, 09:30:12 PM »
HumViewer looks for the .DAT file.  They are stored in the RECORD folder.
Offline Dam Yankee
  • Software: 4.780
« Reply #4 on: April 17, 2010, 06:27:39 AM »
No record folder. Hummviewer sees no files on the SD card at all.
Offline rstell47
  • Unit(s): 998
  • Accessories: Barometer ASGRHA
« Reply #5 on: April 17, 2010, 09:08:57 AM »
    I had the same problem...happened twice, changed SD cards and it has not been a problem since. Not sure if the card was the culprit, just don't want to take a chance on loosing more recordings.
Offline Dam Yankee
  • Software: 4.780
« Reply #6 on: April 17, 2010, 12:54:07 PM »
That is a let down. Wonder which one I should buy. Looks like I wasted my money on an 8 and 4 G. SD card.
« Reply #7 on: April 17, 2010, 03:14:15 PM »
Can you see the files on your computer?  Insert the card and open the SD Card drive.  There should be a RECORD folder if you have made some recordings.
I would copy the entire RECORD folder over to a folder in your My Documents and then in HumViewer browse to the files there.
Offline pig75
  • Unit(s): 798, matrix17, lcr400
« Reply #8 on: April 17, 2010, 05:26:23 PM »
If the SD cards are SDHC can your card reader read them? I have 5 card readers and only 1 reads SDHC cards
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #9 on: April 17, 2010, 05:36:39 PM »
Pig is right about the SD card reader.
If you have a SD card that is bigger than 2 Gigabytes, you need a HCSD compatible card reader to read your card. HC stands for "high capacity" and everything bigger than 2 GB is high capacity.
Regards / Harry
YES,......
WE SCAN!
Offline Dam Yankee
  • Software: 4.780
« Reply #10 on: April 17, 2010, 07:17:39 PM »
That has to be it. Thank you guys. Got to get an SDHC card reader first tomorrow after work. Will post in this same thread afterwards so maybe someone else can learn from it as I am sure I will run into something else. LOL!
My first time using an HDSC card. Just thought it fit so it must read it.
Offline salvor6
  • Pirate of the Martires
  • Unit(s): 1198c Si Combo
  • Software: 6.64
« Reply #11 on: April 18, 2010, 01:33:20 PM »
Yes, I have the SanDisk card reader and it won't read SDHC cards. Luckily my Hewlett Packard printer has card slots and it will read the SDHC cards.
Offline Dam Yankee
  • Software: 4.780
« Reply #12 on: April 18, 2010, 05:12:47 PM »
Good thing we are talkin this stuff out. You just saved me some money bud!! I have a brand new HP printer too and come to think of it I have some slots and I bet one is anHDSC card slot also! Thanks. Will check in a couple hours when I get off work.
Tom
Offline Dam Yankee
  • Software: 4.780
« Reply #13 on: April 22, 2010, 07:16:39 PM »
Wound up having to get a sdhc card reader at wally world for 8 bucks. Works fine! Looks like the recording from the trolling motor isn't very good probably not fast enough. but I was pretty succesful with recording from the rear ducer. I seem to get the best reults at about 3 miles an hour. It is amazing what is in spots that I have fished for a while.
Now to take it up another level. Need to figure out how to go about marking waypoints and getting them on the unit. Havin fun figuring this stuff out and learning a lot.
Does anyone have experience with the speed and settings on the SI maybe some baseline settings?
Offline Jolly Roger
  • HB Addicted
« Reply #14 on: April 24, 2010, 01:47:33 PM »
Dam Yankee,
I wrote something about chart speed / boat speed here:
http://forums.sideimagingsoft.com/index.php?topic=242.0
Regards / Harry
YES,......
WE SCAN!
Offline Dam Yankee
  • Software: 4.780
« Reply #15 on: April 24, 2010, 11:34:39 PM »
Thank you Harry. I am looking forward to the next time out to experiment. ;)
Last post April 07, 2016, 10:27:19 PM
by dakota
Last post January 25, 2015, 03:18:20 AM
by matt@reefmaster
Last post January 20, 2014, 12:05:41 AM
by salado
