Author Topic: Solix side imaging problems  (Read 10097 times)
Offline Map112377
  • Unit(s): Helix 5 si gps
  • Software: It's a new unit
  • Accessories: No
« on: August 28, 2023, 10:15:45 AM »
So can someone tell me whats going on here? Ive reset the settings to factory, checked power, moved the transducer around and it shows me a darker image on one side and then a fuzzy looking image at other times as in the pictures. Just dont look right to me. Theres nothing obstructing the views of the transducer either that i have checked 🤷‍♂️  i have a tracker pro 175 txw with the stepped hull. The factory location for a transducer is left of the motor at the bottom by the livewell fittings. Should i place it on the right side?
Re: Solix side imaging problems
« Reply #1 on: August 28, 2023, 09:48:47 PM »
Remove the xducer from the bracket and stick it way down in the water to verify there is nothing on the boat causing an obstruction  ...
If the image is the same - then the xducer may be failing  ...
Offline Map112377
  • Accessories: No
« Reply #2 on: August 28, 2023, 11:45:41 PM »
Gotcha, good idea ill definitely try that. I was wondering also if it could be the location i have it mounted at. as i have it mounted in the stock location of the old transducer that came on the boat from tracker (from what i understand) which is on the lower port side which i find odd why they would do that so ill also try moving it to the starboard side at some point also.
Last post May 07, 2013, 11:39:25 AM
Last post November 17, 2013, 08:50:09 PM
Last post August 03, 2016, 06:08:47 PM
Last post August 07, 2017, 08:14:06 PM
Last post December 29, 2017, 11:23:06 AM
by bigkahuna
