Author Topic: Airmar TM150C-M-HB and helix 10 MSI G4N and y-cable  (Read 11261 times)
Offline Nickd
  • Unit(s): 899c si, 1198c si
  • Software: Latest
« on: June 09, 2023, 03:52:31 PM »
Does anyone have any experience using this combo?  I just purchased a Helix 10 G4N to replace an old 1198c.  Have the new HDSI MSI ducer and want to use an Airmar TM150C.  I see now Airmar makes a direct plug in TM150 to HB.  Will it work with the Y-cable for MSI ducer?  Can I set the frequencies for the Airmar and just let it go?  Any guidance?
Thanks...N
Re: Airmar TM150C-M-HB and helix 10 MSI G4N and y-cable
« Reply #1 on: June 09, 2023, 09:14:31 PM »
I do not know what the frequency capability of the Airmar is  ...
I do know that you have control of the CHIRP frequency ranges (2d/DI/SI) by accessing the “CHIRP Configuration” Menu under the Sonar tab  ...
Offline Nickd
  • Software: Latest
« Reply #2 on: June 12, 2023, 07:56:06 AM »
Thanks.....Well here is what I found out from HB....Not that helpful, but some info.
It SHOULD work....Not a great answer coming from a company that has an entire PDF dedicated to all the airmar products they support.  It will work directly connected.  If I use it with the Y cable, I can set frequencies (95-155) by hand.
I guess thats the best I can get.  When i asked if they tested any with the Y-cable, They reacted like i had 3 heads.  I mean come on......thats probably the most used option!!
Anyways, the ducer arrives tomorrow.  Will test and post back.  Honestly, the easiest solution for all this mess is to put 2 ducer inputs on all these screens.  Solves a bunch of issues and less cables to worry about!
N
Offline MarjanK
  • Unit(s): 898c, Helix 7 DI G2
  • Software: ?
  • Accessories: GPS receiver
« Reply #3 on: October 18, 2023, 01:03:04 AM »
Hi NickD
Did you get it and try it? Are both transducers working?
I am also interested and would be happy to have a concrete test. Thank you.
Last post November 01, 2016, 08:07:45 PM
Last post June 16, 2017, 09:06:36 AM
Last post November 23, 2018, 09:52:54 PM
by henz
Last post October 27, 2019, 04:49:01 AM
by reso
Last post August 12, 2020, 11:29:34 PM
Last post October 29, 2021, 08:47:11 PM
Last post April 18, 2023, 11:29:21 PM
Last post June 02, 2023, 09:14:12 AM
by kpkyllo
