Author Topic: Possible Dual Purpose Y-Splitter Cable  (Read 14715 times)
Offline Swann
  • The word IF is only 2 Letters But over 3miles Long
  • Unit(s): N/A
  • Software: N/A
  • Accessories: XNT9 QB90 Transducer
« on: September 02, 2022, 10:16:18 PM »
Hello Everyone,
I've got another Loaded question 4any1 that may have attempted this is the past:
IF I were 2 purchase an ASI-LR-Y-Splitter cable & then found a strange way to "cap/cover" 2 of the 5 pins of 1 Side in order 2make it "look like" an ASI-DB-Y-Splitter Cable - Would the ASI-LR-Y now Function the same as an ASI-DB-Y ?
Would it be possible 2make a Dual Purpose Y-Splitter Cable in this manner?
Thanks,
Sandro
Re: Possible Dual Purpose Y-Splitter Cable
« Reply #1 on: September 03, 2022, 07:19:59 PM »
Is the idea just to save the cost of another cable ??
Offline Swann
  • Unit(s): N/A
  • Software: N/A
« Reply #2 on: September 03, 2022, 07:26:09 PM »
More/Less - Yes.
« Reply #3 on: September 03, 2022, 09:50:13 PM »
If you cap, cover or remove any of the circuits it would make that circuit inoperable  ...
The above is the same pinout for the AS SIDB Y Cable end - and the AS SILR Y Cable end that connects to the head unit  ...
« Last Edit: September 03, 2022, 10:03:28 PM by rnvinc »
Offline Swann
  • Unit(s): N/A
  • Software: N/A
« Reply #4 on: September 04, 2022, 07:36:16 AM »
Thanks the sketch SIr,
I have them too and figureing the cable 2look moreso like "a circuit" than just a cable and No, I wouldnt be so foolish as 2remove pins #1 and #3 - just thinking 2 "block" the LR SI signals. Now I'm No Expert but I will be wondering "why" this wouldnt work.
Thanks, Sandro.
« Reply #5 on: September 04, 2022, 01:08:19 PM »
Making the R SI  (pin1) and L SI (pin3) circuits inoperable would allow only the 2d and temp circuits to be operable  ...
Basically turning the AS SILR Y cable into this  ... :
With no R SI circuit (pin1) or L SI circuit (pin3) it would not be comparable to the AS SIDB Y Cable nor the AS SILR Y Cable  ...
« Reply #6 on: September 04, 2022, 07:16:04 PM »
Maybe I’m still not fully understanding your idea  ...
Is the idea to cap, cover, mask some pins in the AS SILR Y cable and it work as an AS SIDBY Cable  ... ??
Offline Swann
  • Unit(s): N/A
  • Software: N/A
« Reply #7 on: September 05, 2022, 12:15:58 AM »
Yes Sir,
Cap or Cover or Mask Pin#1 + Pin#3 of one Side of the ASILR 2make it "look" just like an ASIDB... BUT U Know what, it just dawned on me... NO, It Will NOT Work b/c an ASILR is designed 2split the SI signal into 2separate Left/Right Readouts so Even "IF" my crazy idea did somehow work for the DB Side by way of masking Pin#1 and Pin#3 of either the Left or Right Connector End - One Would only achieve a Half Screen of Side Imageing with the other side being "Blank". Well, there goes that idea.
Just so U know, Shipping really sucks up here in The Great White North and many times, the cost of something as simple as an ASIDBY cable is doubled just b/c of Shipping... so when that cost for accessories keeps going up - one must find creative "work-arounds" w/o damaging the actual part itself. Just needed 2think out-loud I guess and was unable 2see the Forrest 4the Trees.
Thanks Again,
Sandro.
Last post July 29, 2010, 11:11:21 PM
Last post April 23, 2012, 01:11:57 PM
Last post August 07, 2012, 05:45:16 PM
by Paul D
Last post April 08, 2013, 01:29:07 PM
by Warrior12934
Last post January 17, 2017, 11:37:14 AM
Last post December 14, 2019, 12:12:02 PM
Last post January 15, 2022, 04:20:46 AM
by TimTDP
Last post November 17, 2023, 07:31:19 PM
