Author Topic: 360 or original transducer  (Read 7785 times)
Offline kentman
  • Unit(s): solix 15 mega 360
  • Accessories: gps antenna
« on: July 26, 2021, 11:16:39 AM »
Hi all
We bought a Solix 15 G2 which came with its standard transducer about 2 years ago. When the 360 became available I fitted it and updated the software and it now uses the 360 transducer exclusively. Am I dreaming or did I read its now not possible to use the old transducer as the main one, or can I tell the head unit to switch back to use the original transducer?
Now we have the 360 which is great, I'd like to build the original transducer into a towfish for more accuracy in deeper waters. I don't want to have to buy a second screen however.
Chris
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
Re: 360 or original transducer
« Reply #1 on: July 26, 2021, 08:10:31 PM »
i think as long as the 360 is in function the SI is not functionning on the tranducer but other functions should work and you should be able to choose wich SI you want to use
« Reply #2 on: July 26, 2021, 10:15:03 PM »
Original G1 360 is an Ethernet connection with its own separate power cable  ...
As long as the 360 has power - 360 and SI come from the 360 xducer  ...
Install a toggle switch on the 360 power  ...
Switch power off to the 360 to regain SI from the stock xducer  ...
« Last Edit: July 26, 2021, 10:40:45 PM by rnvinc »
Offline kentman
« Reply #3 on: July 27, 2021, 07:42:31 AM »
Thanks for the quick replies. Lets give this a try then. Cheers Chris
by Sonshine Fishing
by Brian37075
by jgcox6
Last post September 29, 2013, 11:45:33 AM
by bobcoy
Last post July 16, 2015, 10:52:34 AM
by Beaulieu80
Last post August 16, 2016, 10:52:51 PM
by mike fish
