Author Topic: Towfish setup - for reducing wave motion  (Read 2092 times)
Offline Boue
  • Unit(s): Helix 9
« on: December 26, 2020, 05:08:57 PM »
Hello,
Firstly, wow, what an amazing forum, so much knowledge.
I am a proud new owner of a HB Helix 9 with Mega SI+ transom mounted ducer, which I intend on using for seabed habitat mapping in seawater approx 10m to 50m deep.
I am at a fairly exposed coastal location, so the sea is rarely as calm as I would like it, which means the number of days where the sea is flat enough to capture really good SI data are limited.
I am therefore thinking that a towfish would help removing the roll and pitch of the boat (21ft motor cruiser with outboard).
Does anyone have any recommendations for a setup to simply remove the motion of the boat. I don't need to get the ducer much deeper, just remove the wave action. I also have a down rigger on the boat.
I am considering lowering the down rigger just enough to clear the outboard, then streaming a towfish 5m or 10m behind it?
Would such a setup achieve my objective of steadying the ducer from the motion of the boat?
All and any comments or advice greatly appreciated.
Thank you
Tim
Offline Rüdiger
Re: Towfish setup - for reducing wave motion
« Reply #1 on: December 27, 2020, 04:07:20 AM »
Welcome to the forum Tim :)
You're right, a towfish is the best solution to minimize boat and water movement. Here in this forum you will find many examples of construction. I also only use three standard extension cables for towing, but with an additional line for strain relief.
Have fun building it yourself and let us be a part of it.
mvh
Rüdiger
Offline abraquelebout
« Reply #2 on: December 29, 2020, 01:24:20 PM »
hi
Rüdiger is on the right.
I use towfish in salt water for various deep (3 to 60m),, but 10 m câble seem's short.
Think there's few meters on board to connect the unit (4 or 5m) and if there's more waves the movements of the ship give a wrong traction to towfish (some bad movements).
My first short towcâble is 30 m and the second for 60 m deept is100m, with the 30 m i get a good result with a  bad weather (1m short waves and 15 to 20 knots wind) at 7 to 10 meter depht . ..the towcâble is all over  board at this moment.
Offline Boue
  • Unit(s): Helix 9
« Reply #3 on: December 29, 2020, 03:50:52 PM »
Hello both,
Thank you very much for your advice.
Rüdiger - do you use a downrigger with your towfish?
Thank you
Offline Rüdiger
« Reply #4 on: December 30, 2020, 03:54:44 AM »
Hi Tim
I don't use a downrigger, as an alternative to the usual rocket shape for a towfish, here's a good idea:
http://www.treasurenet.com/forums/shipwrecks/579733-towfish-vs-downrigger.html
mvh
Rüdiger
Last post December 23, 2011, 05:46:26 PM
by tommyboyrn
Last post November 20, 2012, 03:14:56 PM
by sarasotawingman
Last post May 28, 2013, 12:27:17 PM
Last post February 28, 2014, 04:37:18 AM
by Rüdiger
Last post May 10, 2015, 10:39:36 PM
Last post January 27, 2016, 11:30:58 PM
Last post May 10, 2016, 12:45:12 PM
by Spd 135
Last post July 04, 2020, 09:56:24 PM
