Author Topic: HELIX 7 MSI G3 SI navigation doesnt appear  (Read 12156 times)
Offline Zubacobijec
  • Unit(s): Helix 7x chirp mega si gps g3
« on: October 04, 2020, 12:56:22 PM »
Hello guys i have Helix 7 MSI G3 and SI navigation on SI screen doesnt appear even if its turn on in menu. Any ideas?
Thanks.
Mark Slovakia.
Re: HELIX 7 MSI G3 SI navigation doesnt appear
« Reply #1 on: October 04, 2020, 09:17:52 PM »
Chart views, the Nav tab, and the Chart tab will not show unless the unit has locked onto the satellites.
If you are outside where the unit’s internal GPS antenna can see the sky, if the unit is in Normal operating mode, and you have waited a few minutes for the antenna to connect to the satellites - and the unit still does populate Chart views or the Nav tab and Chart tab = it is possible the internal GPS antenna has failed.
1st try Restore Defaults  ...
If that does help there are 2 options  ...
1. Connect an external GPS antenna. Read here about connecting an external GPS antenna to a HELIX 7 https://www.humminbird.com/support/faqs/HELIX_EXT_GPS
2. Contact your HB dealer  ...
« Last Edit: October 04, 2020, 09:19:21 PM by rnvinc »
Last post May 13, 2010, 08:54:01 PM
by Piscivorous Pike
Last post April 28, 2011, 10:31:53 AM
Last post April 12, 2012, 06:52:44 AM
by tokerwashere
Last post February 08, 2013, 11:11:48 PM
Last post January 28, 2014, 02:54:02 PM
Last post March 24, 2014, 04:05:17 PM
by Rickard
Last post April 21, 2014, 06:59:43 PM
by fishermanatr
Last post August 02, 2016, 12:15:33 PM
by D S
