Author Topic: Autochart Live data goes bad  (Read 611 times)
Offline knorstu
  • I work therefore I fish!
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« on: April 01, 2020, 01:53:20 PM »
Hi. Didn't really get an answer earlier. How does the data go bad? Not a good sign that Humminbird provides a feature to delete Autochart data. Thanks.
Re: Autochart Live data goes bad
« Reply #1 on: April 02, 2020, 09:43:18 AM »
Although I’m not an AutoChart user - I have read many instances where digital depth issues (with software, faulty xducers, bad connections) can cause “bad” AutoChart data  ...
And then users would go into the data files in the AutoChart PC software and delete those individual “bad” data points  ...
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #2 on: April 02, 2020, 10:05:02 AM »
Makes sense. In my case, the data was fine when gathered but changed after shutting down and restarting. It was only a small portion of data. No changes made to the setup.
Offline rbdavis3591
  • Unit(s): Helix 9 SI
  • Software: Unknown
  • Accessories: None
« Reply #3 on: April 02, 2020, 10:59:20 AM »
The first result from a Google search for "Autochart Live bad data" pointed to a Technological Angler video https://www.technologicalangler.com/repair-autochart-live-maps where he gives an example of the user causing the bad data.
Quote
If you do enough mapping with AutoChart Live, you'll eventually end up with a piece of bad depth data or two, data which will lead to inconsistent mapping. Bad data typically arises from a rapid change in boat speed or a quick turn, both of which can produce turbulence beneath the transducer and result in a bad piece of depth data.
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #4 on: April 02, 2020, 11:03:28 AM »
That implies the data was bad when it was first charted. Mine wasn't.
Offline rbdavis3591
  • Software: Unknown
  • Accessories: None
« Reply #5 on: April 02, 2020, 11:54:58 AM »
Quote
I guess you would have to analyze the bad data that occurred between the time you shut down AutoChart Live and you restarted it.
What is your bad data? Wrong depth? Wrong GPS location? Wrong date/time? Location of data such as beginning, middle, end of recording.
Also when the data went bad was it being recorded on the internal memory or to a memory card?
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #6 on: April 02, 2020, 12:40:09 PM »
The data was depth. Recording on the card.
Last post July 09, 2015, 03:15:33 PM
by CamoHunter
Last post April 24, 2016, 10:56:12 AM
by Rpadar
Last post July 31, 2019, 09:03:54 PM
Last post August 02, 2019, 02:35:25 PM
by knorstu
Last post September 12, 2019, 05:39:17 AM
by danceswithbass
Last post April 01, 2020, 08:58:39 AM
Last post April 18, 2020, 10:02:41 PM
Last post April 28, 2020, 03:59:22 PM
