Author Topic: Bathymetry Helix 5 Sonar G2  (Read 7076 times)
Offline J.Hellevoort
  • Unit(s): HELIX 5 SONAR G2
« on: March 19, 2020, 12:38:46 PM »
Hello,
I am a student in the Netherlands studying hydrography and currently I am doing research to cheap solutions for gaining bathymetric information of shallow waters. For this research one of my solutions is a fishfinder. Is it possible to connect a externe GPS receiver to the fishfinder and to output real-time NMEA messages including depth with corresponding position to a pc through a comport (not usb because of latency problems)? Something like this scheme.
If this couldn't be done I would really appreciate alternative ideas.
Thanks!
Jort
« Last Edit: April 22, 2020, 05:28:40 AM by J.Hellevoort »
Re: Bathymetry Helix 5 Sonar G2
« Reply #1 on: March 19, 2020, 10:33:12 PM »
This may help with part of your query  ...
https://www.humminbird.com/support/faqs/HELIX_EXT_GPS
« Reply #2 on: March 20, 2020, 08:16:23 AM »
Yes it helps for connecting the gps to the fishfinder. But after that, how can I connect the fishfinder to a pc? It is possible, according to the manual to switch on NMEA output, so the fish finder outputs NMEA messages.
« Reply #3 on: March 21, 2020, 09:48:27 AM »
See if this helps  ... (I have no experience with NMEA)  ...
https://www.humminbird.com/support/faqs/how-do-i-output-digital-depth-information
« Last Edit: March 21, 2020, 09:49:47 AM by rnvinc »
« Reply #4 on: March 25, 2020, 08:34:08 AM »
Like that you can connect the fishfinder to the pc and output depth to the pc. But it uses a USB port and not a COM port. A USB port introduces to much latency for my project. So that's not an option.
« Reply #5 on: March 25, 2020, 11:35:51 PM »
Here is some contact info  ...
https://www.johnsonoutdoors.com/locations?id=127
Offline abraquelebout
« Reply #6 on: March 28, 2020, 05:52:35 AM »
hi
you can connect lot of thing talking in nmea using a "multiplexeur", it collect nmea sentences, sounder, gps and put them on rs232 db9 connect (it's old) or usb (recent)
reefmaster can make a bathymetry using Humminbird or other system
i join a pdf (in french)
good luck, it's possible to do it, i go on my stock of lot of thing to search, i think i get an old model on a case (sounder, gps, multiplexer, rs232 connect for PC)
« Reply #7 on: April 22, 2020, 04:32:54 AM »
Thanks everyone for helping me out!
I found a way to connect an external GNSS receiver to the input of the Helix 5 and connect the output to my PC. For anyone who wants to know how, I will explain:
1. I bought the Humminbird AS HHGPS cable (it comes with a y-cable as well but I didn't use that one).
2. I cut the cable in two and connected it as shown in the image below.
3. I attached RS-232 DB9 connectors to both ends of the cable to connect it to the GNSS receiver and my laptop.
4. When everything is tuned in on eachother (correct baudrates etc.) I get NMEA 0183 messages on my laptop.
I didn't want to connect the Helix 5 to my laptop via USB because of latency issues. If you don't have a RS-232 comport on your PC/laptop you can buy a device like the Moxa NPort-5110.
I still have some problems to solve now:
1. The output rate of the Helix 5 is to low, I want it to output NMEA messages at 10 Hz.
2. My GNSS receiver sends correct altitudes in the GGA string to the Helix 5, but the Helix 5 doesn't send this correct altitudes to the laptop.
Example of a GGA string, the two altitudes are bold:
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
My Helix 5 only sends the first altitude to my laptop and leaves the second altitude as a blank field.
If someone knows how to solve these problems I would really appreciate that.
Last post January 31, 2016, 05:32:33 PM
Last post May 20, 2016, 10:56:27 AM
Last post June 29, 2016, 08:23:02 PM
Last post October 28, 2016, 06:47:32 PM
Last post January 07, 2017, 06:28:25 PM
Last post May 25, 2017, 08:16:21 PM
by wolfgrw
Last post July 13, 2017, 09:12:14 PM
Last post April 14, 2019, 08:57:18 PM
