Author Topic: Sticky buttons  (Read 1471 times)
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
Sticky buttons
« on: December 02, 2019, 06:36:50 PM »
Anyone have an easy fix for sticky buttons?  My 998 always has one or two, not always the same ones, but it always seems to be the one I need to work only when it doesn't...
Re: Sticky buttons
« Reply #1 on: December 02, 2019, 10:31:37 PM »
Sometimes a sticky button can be attributed to the button pad being out of alignment with the button holes of the plastic bezel  ...
The faceplate would need to be removed to align the button pad  ...
  • Unit(s): 998c SI
  • Software: ??
Re: Sticky buttons
« Reply #2 on: December 03, 2019, 11:24:31 AM »
Thanks,  I guess I should clarify that they don't actually stick, they just don't work when you push them.  Sometimes I push it 3 dozen more times and it starts to respond.
Offline ezfishn
  • Unit(s): H12 SI, H10 SI, 1198, 998 HDSI
  • Software: 1.64,1.64,6.74,6.74
  • Accessories: Ultrex Ipilot/Link, Ethernet Sw
Re: Sticky buttons
« Reply #3 on: December 03, 2019, 05:33:15 PM »
With my 998, I sometimes have a problem with the power button but the rest of the buttons are ok.  When powering down, sometimes have to press just the edge of the button.
Re: Sticky buttons
« Reply #4 on: December 03, 2019, 10:50:32 PM »
A non-responsive button can also be attributed to 1 of the other buttons being stuck in the "contacted" state under the bezel  ...
  • Unit(s): 998c SI
  • Software: ??
Re: Sticky buttons
« Reply #5 on: December 10, 2019, 06:44:33 PM »
Thanks, I'll look at all of the above.
Last post November 21, 2011, 04:41:58 PM
Last post May 09, 2012, 07:37:19 AM
by ITGEEK
Last post July 09, 2013, 01:44:27 PM
Last post November 23, 2014, 09:32:55 AM
by FJJJGSTRIPER
Last post January 23, 2015, 09:07:25 AM
by cache22
