Author Topic: Info Sonar tab  (Read 10258 times)
Offline levert
  • Unit(s): 798si ci
  • Software: 7.6
  • Accessories: sonar
Info Sonar tab
« on: August 30, 2019, 09:04:23 AM »
I bought a used boat 2 years ago, a sonar gps 798 ci  installed. In the SONAR tab, there is the choice of either: quad beam or side scan available. Does that mean that I have the probe the quadra beam, or if it is by default and always present.Thanks!
Re: Info Sonar tab
« Reply #1 on: August 30, 2019, 09:44:48 PM »
The unit does not automatically detect which xducer is connected to the unit  ...
You have to tell the unit which xducer you have connected so that the unit can transmit the correct frequency options for the xducer you connected  ...
There should be indication on the xducer cable close to the connector end that indicates that xducer model  ...
The stock xducer for the 798ci SI is the XNT 9 SI 180 T  ... and the correct "Connected Transducer" selection  for that xducer is "Compact Sidescan"  ...
This selection will allow the 798 to transmit 83/200kHz for 2d Sonar and 455kHz for SI/DI  ...
« Last Edit: August 30, 2019, 09:47:33 PM by rnvinc »
Offline levert
  • Unit(s): 798si ci
  • Software: 7.6
Re: Info Sonar tab
« Reply #2 on: August 31, 2019, 07:40:29 AM »
Thanks for your answer!!
Last post October 18, 2009, 07:40:11 PM
Last post November 25, 2011, 03:12:42 PM
Last post April 03, 2012, 07:05:51 PM
Last post November 14, 2013, 12:10:09 PM
Last post January 31, 2016, 03:30:28 PM
Last post May 03, 2018, 12:46:19 PM
by freezerfiller
Last post July 25, 2018, 09:53:01 PM
Last post July 03, 2024, 08:11:57 PM
