Author Topic: Still helix issues  (Read 776 times)
Offline tundra
  • Unit(s): helix 9, helix 9, helix 7
Still helix issues
« on: June 26, 2019, 10:47:31 PM »
I donít know if I should just scrap these units or what. Helix 9 mega g2n and helix 7 g2n connected on dash using the mega ducer. Can never get a good 2d sonar reading and now depths are all over the place. Mostly read 1.1ft. Si works great though other than freezing up occasionally. Could I have a bad transducer or wouldnít that cause the depth issues? Everything is updated and restored defaults several times. High speed ducer barely ever reads either. Very frustrating
Offline tundra
Re: Still helix issues
« Reply #1 on: June 26, 2019, 10:50:30 PM »
Iím thinking about installing the helix 7 transducer on the transom to see if the sonar will at least work on that. How far does it need to be from the mega ducer so they donít interfere w each other?
« Reply #2 on: June 27, 2019, 07:50:17 AM »
Are you using a Y cable  ...??
If so, is the secondary 2d xducer in the bilge or on the transom  ...
Offline tundra
« Reply #3 on: June 27, 2019, 02:07:32 PM »
Yes, mega y cable and the 2d ducer in bilge. Went out today and the 7 was froze up right away, so I restored defaults again and the depths were good whole time, even high speed. Lake was flat today though, not sure if it matters. The sonar seemed to work better today also, I think I have it in max mode in order to show a solid bottom.
« Reply #4 on: June 29, 2019, 12:06:20 AM »
It sounds like the bilge xducer may not be in the optimum spot and that part of the hull is coming out of the water in chop  ...
Offline tundra
« Reply #5 on: July 02, 2019, 08:56:37 AM »
That makes sense but the depths donít always work when Iím just idled or sitting still.
« Reply #6 on: July 02, 2019, 10:50:36 PM »
This sounds like the bilge xducer may be faulty or coming loose from its epoxy  ...
You might try disconnecting the Y cable and test the SI xducer plugged directly into the unit  ... If the 2d reads correctly at idle or stationary you can suspect the bilge 2d xducer  ...
Offline tundra
« Reply #7 on: July 03, 2019, 09:12:31 AM »
But shouldnít the main transducer be reading the 2d at idle? I noticed yesterday that the when I unload boat in shallow water or if Iím in deeper water and go to shallow, the depths quit working, and when I idle out to deeper it takes the graphs about about 20-30 yards before the graphs unfreeze and start reading depths.
Offline ezfishn
  • Unit(s): H12 SI, H10 SI, 1198, 998 HDSI
  • Software: 1.64,1.64,6.74,6.74
  • Accessories: Ultrex Ipilot/Link, Ethernet Sw
« Reply #8 on: July 03, 2019, 11:17:46 AM »
When using a y-cable, 2D is hardwired from the secondary DualBeam transducer.  There is no electrical path for the 2D from the imaging transducer.
Offline tundra
« Reply #9 on: July 03, 2019, 07:28:02 PM »
So your saying since I have the y cable, Iím never getting 2d from the mega ducer. I assumed the shoot through transducer is only for high speed. If thatís the case I shouldnít be losing depth in shallow water.
« Reply #10 on: July 03, 2019, 09:24:09 PM »
Like ezfishn mentioned there is no switching of 2d source  ... With the Y cable, 2d always comes from the 2d xducer  ...
To troubleshoot the bilge xducer remove the Y cable and connect the SI xducer directly to unit  ...
If 2d stabilizes - your issue is the 2d xducer, it's epoxy mounting, or the Y cable is bad  ...
« Last Edit: July 03, 2019, 10:39:13 PM by rnvinc »
Offline tundra
« Reply #11 on: July 04, 2019, 09:32:06 AM »
Ok, I will try that next. Another question with that, do I need to change my sonar settings because it will only read off the shoot through 2d? I believe The sonar is set at mega chirp or something like that.
« Reply #12 on: July 05, 2019, 12:11:32 AM »
Leave the Connected Transducer selection at MEGA and test without the Y cable  ...
This will transmit MEGA SI, MEGA DI, and 2d  ...
If the 2d functions correctly then the bilge 2d xducer is faulty, has come loose from its epoxy mounting, or the Y cable is bad  ...
Offline tundra
« Reply #13 on: July 05, 2019, 10:40:18 PM »
I disconnected the y cable and it ran good. Reads fine in shallow water. Now how do I know if itís a bad y cable or bad 2d ducer? The 2d ducer works fine on plane if the graphs are reading depth when I take off.
« Reply #14 on: July 06, 2019, 09:48:11 PM »
Plug the 2d xducer directly into the unit without the Y cable  ...
Change the Connected Transducer selection under the Sonar tab to HB 83/200kHz
Test  ...
Offline tundra
« Reply #15 on: July 07, 2019, 06:00:23 PM »
I went directly into the helix 7 with the 2d and switched to 83/200 and canít get any readings. I plugged the 2d back into the y cable and still donít get readings in shallow but works good over 4í still. I guess Iím wondering if the 2d ducer is bad, why will it work in deeper water? Does this mean that the y cable is good?
« Reply #16 on: July 07, 2019, 08:50:08 PM »
Do the very same test with the HELIX 9 instead of the 7  ...
I'm not really sure why its working in deeper water and not at all in shallow water  ...
Offline Gimp
  • Unit(s): 998 HD SI
  • Accessories: i-Pilot Link
« Reply #17 on: July 07, 2019, 08:51:11 PM »
Just curious, in shallow water, under 4 feet, have you tried to adjust the Surface Cluttler?
Offline tundra
« Reply #18 on: July 07, 2019, 10:03:15 PM »
The graphs pretty much freeze up in shallow and donít move until I get to deeper water.
Offline tundra
« Reply #19 on: July 07, 2019, 10:10:25 PM »
I will do the test with the 9 next weekend when I get back on the water and report back.
Offline tundra
« Reply #20 on: July 28, 2019, 11:31:33 AM »
I installed a new 2d transducer in the hull and it works good now.
« Reply #21 on: July 28, 2019, 10:27:40 PM »
Yay!! This was a challenging one for sure  ...
by fishinphil
Last post May 19, 2015, 12:07:30 AM
by CATNIP
Last post January 15, 2016, 04:14:26 PM
by Boschy
Last post February 19, 2018, 08:24:42 PM
by Whistler
Last post August 05, 2018, 08:50:43 PM
Last post January 31, 2019, 08:48:52 PM
Last post March 06, 2019, 04:12:29 PM
by P_Frost7
Last post May 10, 2019, 08:52:52 PM
