Author Topic: 859 wont power up  (Read 6862 times)
Offline possum1
  • Unit(s): 998c hd si
859 wont power up
« on: April 04, 2019, 10:59:26 PM »
Have 2 units 859 and 998, not connected in any way except both hooked to crank battery. Yesterday at end of fishing day, Started main engine, 859 cut off, 998 kept power. Today 859 cursor light will light up but nothing else happens. Simple blank dark screen. Wont cut off, have to remove power from battery to shut down. Any ideas? Thanks possum1
Re: 859 wont power up
« Reply #1 on: April 06, 2019, 06:27:51 PM »
Power issues when the big motor is cranked can be from a bad (or low) battery  ...or insufficient wire size to carry the needed amperage to run the unit   ...
You might think about temporary wiring the unit direct to the battery with just the 6' power cord that came with the unit to see if the unit is the problem or if the wiring circuit to the unit is the problem  ...
Last post April 07, 2011, 04:52:07 PM
by tjj
Last post June 15, 2012, 06:37:54 PM
by jsiegle24
Last post February 02, 2016, 09:04:19 AM
by sorin tot
Last post April 28, 2014, 10:19:40 PM
by wolfman111471
Last post August 25, 2014, 02:22:19 PM
Last post August 12, 2019, 11:55:10 PM
by Jamykid
