Author Topic: Problems with HELIX 9 and 10 CHIRP MEGA SI GPS  (Read 3871 times)
Offline steelebob
  • 1994 TRACKER NITRO 160 and 4 cyl 2017 Yamaha 70 h
  • Unit(s): Helix 2nd gen 10 and 9
  • Accessories: Ulterra
« on: September 05, 2018, 04:25:29 PM »
1. Is this a correct statement : "Saved Tracks Default settings will ONLY be applied to NEW TRACKS ONLY, WHEN IMPORTING" So that older tracks have to be individual edited??
2. Anyone having problems with the unit and the supplied gimbal not fitting properly. I cant adjust them to where they work "smoothly" like my 898 did. That in between setting where you can tile it just right. Right now the head is either frozen in place or falls off the gimbal.
3. My non-networked 10 will only show "bullseye" WP icons, where the same uploaded WP on my 9 are fine. Tried alot of the usual fixes.
4. What's the max # of WP you can use at one time?
« Last Edit: September 05, 2018, 04:57:12 PM by steelebob »
I dream of things that never were, and ask why not?
Re: Problems with HELIX 9 and 10 CHIRP MEGA SI GPS
« Reply #1 on: September 05, 2018, 08:50:46 PM »
1. This is correct  ... "Saved Tracks Default" selections only applies to future saved tracks  ...
2. I frequent several forums and this is the 1st note of the gimbal not holding the unit correctly  ....are the round serrated disks present on both the gimbal ends and in the head unit case insets  ...??
3. Please clarify  ... I'm not fully understanding the scenario  ...
4. Waypoints capacity in internal memory is 2,500 waypoints  ...
« Last Edit: September 05, 2018, 08:53:30 PM by rnvinc »
Offline steelebob
« Reply #2 on: September 06, 2018, 03:32:22 PM »
As for #2, the gimbal and the unit look the way they should, both have the "rough edging". It's almost like the "rough edging" is too pronounced.
As for #3, ALL the uploaded WP on the 10 have a white circle with a black dot in the middle.
Again this does not happen on the 9 unit, whem I use the same cd card and upload the info  So it is even doing it when I'm networking or not. When I make a new WP then it does what it is suppose to do, I get the blue dot.
« Reply #3 on: September 06, 2018, 10:38:13 PM »
The serrated disks are designed to hold the unit stationary after adjusting to angle desired and then tightening the knobs  ... I'm not sure how one would find a certain tightening spot of the knobs to securely hold the unit and still allow it to be adjusted for tilt  ... I guess it may be possible that the older units may not have had such deep serrations in the disks  ... My 1197 seems to have about the same depth in the disk serrations as my ONIX  ...
Your bullseye waypoints designations I'm not familiar with  ... Have you changed the "Saved Waypoints Defaults" selection to a bullseye  ...??
Offline steelebob
« Reply #4 on: September 07, 2018, 02:25:53 PM »
I shipped off to Humm
Last post October 04, 2017, 06:33:17 PM
by Stumpy
Last post April 26, 2018, 08:35:22 PM
Last post July 08, 2018, 07:55:55 PM
Last post March 14, 2020, 01:34:42 AM
Last post June 06, 2020, 09:52:35 PM
Last post August 11, 2020, 11:12:55 PM
Last post April 14, 2022, 10:09:49 PM
Last post April 15, 2022, 09:46:26 PM
