Author Topic: Wapoint Usage  (Read 11611 times)
Offline Ketchup
  • Unit(s): 798ci
Wapoint Usage
« on: August 12, 2018, 08:18:51 AM »
I have 3000 waypoints on my unit. I am at 2480 (ish). In the process of deleting unused/unnecessary waypoints to make some room. When I make a new waypoint now, it will come up as 2481, no regard to the couple hundred previous waypoints I have deleted. How does that work? When I finally get to 3000, will the next mark be the lowest number of previously deleted and increment from there?
Re: Wapoint Usage
« Reply #1 on: August 13, 2018, 11:14:07 PM »
Previously assigned waypoint labels are not reused after deleting or renaming  ... (I have seen waypoint label assignment reset after some software updates)  ...
The waypoint label assgnment should have nothing to do with actual waypoint capacity (the numbering should continue until max waypoint capacity is reached)  ...
« Last Edit: August 13, 2018, 11:15:40 PM by rnvinc »
Offline Ketchup
  • Unit(s): 798ci
Re: Wapoint Usage
« Reply #2 on: August 14, 2018, 03:57:36 PM »
Once again, Thanx Rickie
Last post November 02, 2010, 09:48:01 AM
by trickyric
Last post May 29, 2011, 02:03:27 PM
Last post February 20, 2015, 04:18:54 PM
by jworks
Last post January 25, 2017, 09:06:06 PM
by jimham82
