Other Humminbird Products => Accessories => Topic started by: Ronny on June 11, 2014, 01:16:50 AM
Title: Cannonlink vs compability
Post by: Ronny on June 11, 2014, 01:16:50 AM
Hi,
I run Cannon Digtroll 5 with Cannonlink, recently I bought a Humminbird 1199 si and 1158cx.
Neither of these works with Cannonlink, I cant find Cannonlink under accessories as I did with the older 858cx.
As far as I understand the 1199 si will not be able to work with the Cannonlink but the 1158 should do so. Could it be that I need an older software version to make it run and if so which one?
Today I run 6.810 on the 1158cx
It isn't fun that something that have worked previously doesn't do so anymore especially since the Swedish retailer didn't inform me when buying the new Humminbirds and I even bought the last Cannonlink available on the market so they should understand that it was critical to me...
Any input appreciated!
Title: Re: Cannonlink vs compability
Post by: Humminbird_Greg on June 11, 2014, 01:55:46 PM
Ronny,
See if you can get your retailer to find this information out for you.  I donít have anything in my 1158 software notes that tells me when the CannoLink was no longer supported.
As for software for your 1158cX unit: you donít want to load software that is older than what the unit was originally built with or it could render the unit inoperable.
Post by: Ronny on July 06, 2014, 04:17:34 PM
Thanks Greg, it turned out that the split cable from the Cannonlink was loose... My fault.
New problem, when trying to run the 1199 together with the 1158 with the ethernet cable and activating the Cannonlink the 1158 blocked completely! Wasn't possible to turn it off even, had to unplug the connector!
Next problem, now the first Cannon Digitroll rig wasn't OK anymore. The only function on the rig itself that is working is the power on/off. Menu, up/down etc totally died!
Its possible to run the rig from the 1158 after disconnecting the ethernet cable but the digitroll also shut down random. This isn't fun when the fishing with the rig 15 meters down and the rig blanks and when starting the unit it says 0 meters instead of 15 meters, then you have to retriew it up with the emergency handle without brake.
I will try a new software tomorrow and see if this helps!
