Side Imaging Forums => Helix Series Units => Topic started by: cade on September 16, 2018, 12:50:15 AM
Title: Can you turn 2d sonar off but still run SI/DI
Post by: cade on September 16, 2018, 12:50:15 AM
Is it possible to disable the 2d sonar 200/83khz but still use SI and DI on a helix 10 mega g2n?
The reason for this is I also run a furuno sounder and the 2d sonar on the humminbird creates interference with the furuno which I would like to prevent.
Title: Re: Can you turn 2d sonar off but still run SI/DI
Post by: rnvinc on September 16, 2018, 05:01:56 AM
Unfortunately 2d cannot be shut off because the unit uses the 200kHz 2d for digital depth  ...
Is it possible to select a different frequency on the Furuno  ...??
