Side Imaging Forums => Solix Series Units => Topic started by: Skeeter07 on June 01, 2018, 06:48:17 AM
Title: 2d transducer lost
Post by: Skeeter07 on June 01, 2018, 06:48:17 AM
Got solix units networked and was picking sonar sources.  I picked for depth 1 the transducer that's connected to unit but said selected 2d transducer (Lost).  After a few min. lost went away.  See picture.  Why would lost show when it connected to unit I was setting it up?  Also why are there two gps and depth to pick?  Is 2 in case number 1 fails? Thanks.
Title: Re: 2d transducer lost
Post by: rnvinc on June 01, 2018, 11:17:33 PM
Networking is designed to "look for" the next best source if the selected source is lost for any reason  ...
A source "Lost" indicates a bad connection or a failing device  ...
You might disconnect and reconnect the xducer connector to see if there may be a bad connection  ...
Post by: TroyBoy30 on August 14, 2018, 11:26:07 AM
it will also show lost on a transducer that has pinging turned off.  there are 2 options for a main and a backup.  some options have as many as 4 options
(http://i287.photobucket.com/albums/ll152/troyboy30/Humminbird/snp0413185641_zpsdxqeg26h.jpg)
(http://i287.photobucket.com/albums/ll152/troyboy30/Humminbird/snp0413185652_zpsbqbzrol3.jpg)
(http://i287.photobucket.com/albums/ll152/troyboy30/Humminbird/snp0413185859_zps8vhxphae.jpg)
