		Other Humminbird Products => Lakemaster AutoChart => Topic started by: snogger on April 20, 2018, 12:24:29 PM
				A few times we've left AutoChart Live running when moving from one location to another, or moved to fast which created bad data points. Following the guides in this forum on how to remove bad data points I was able to remove all of these on my PC.
 I then clicked the "Update ZeroLine" card icon for each area and received confirmation that it updated correctly. Yet, when I put the ZeroLine card back in the Onix and review the maps, the bad data points still show.
 Is there an additional step I need to do to get the "updated" data to show on the Onix, or do I need to manually delete each bad data point on the Onix itself?
 Thanks for any help!!
 As a bonus for the help here is a video I created using AutoChart of an area we are mapping in Canada https://youtu.be/2DPfRd-cIvE (https://youtu.be/2DPfRd-cIvE)
				After you removed the bad data did you click on SAVE?  I have missed that step a few time is why I ask.  Don
				Thanks for the response.. Yes, it is saved as when I go back into the AutoChart program on my PC the bad data points no longer exist.
 My steps were.
 1. Save Sonar recording data from SD Card onto my PC and import into Autochart
 2. Edit Bad data points and save, then click the "Update Zeroline card" - Everything looks great on the PC for printing.
 3. Reinsert the Zeroline card into the Onix and turn it on.
 4. Zoom into the area in Northern Ontario..
 Bad data points still showing :(
