Side Imaging Forums => Helix Series Units => Topic started by: Kablars on January 07, 2017, 01:49:47 PM
Hello, i was wondering if i can run my Helix 5 SI GPS only as a plotter without a transducer attatched? Or will it just enter demo-mode?
I have a better unit for both sonar and SI/DI but no plotter.
I have very litte experience with this kind of things.
Any help much appreciated.
Thank you.
*Power on the unit ... (with or without the xducer attached) ...
*Press "Menu" when the HB logo appears ...
*Choose "Normal" from the popup ...
*Right cursor to activate Normal operation ...
*When the unit has fully booted up - press the power button briefly ...
*Choose "Sonar Off" from the popup window ...
This shuts off the transmitters and allows the unit to be used as a chartplotter only ...
I'm not sure if your model unit will remember this setting change upon a power cycle and reboot ... so test the procedure above after power cycling the unit ...
I will try, thanks alot!
