		Other Humminbird Products => Lakemaster AutoChart => Topic started by: Beaulieu80 on April 10, 2016, 08:27:21 PM
				I just see there is a new update with great new import options.
 what is the CSV format ? i simply can't see it on the HELP
 thank you
				CSV is a file type.  Comma Separated Values....   The data stored in the file is separated by a comma when you look at the file....Usually used with Excel file but others have the decode ability....  Chuck
 date,name,number,gps,depth.  To kind of give you an idea.  The values in the file can be anything..
				I know what a CSV file is.
 Just wanted to know if there was an official maximum of columns and rows and order of the columns to use
 thank you
				that can best be answered by the software developers....
				I try to import and my depth does not show up
 no format example in the new help
				import to Excel and then look at the values....  If they are there on the excel then it is a map program problem...
				I try this format and the depth are way too high in the auto chart, even bigger if i use centimeter values
 48.75852, -72.08913, 10.53
 48.75852, -72.08919, 10.36
 48.75851, -72.08926, 9.87
 48.75851, -72.08934, 9.12
 48.75851, -72.08942, 8.79
 48.75850, -72.08950, 8.66
 48.75848, -72.08957, 8.43
				Not real sure but the depth may be in USA feet...  Do you have that option in the program of setting the chart to feet.
				All my settings are in feet when creating maps
 Humminbird PC use centimeter and convertir on the fly when we see them on the grid to feet
 autochart pc also use centimeter like all fishfinder from humminbird unit does
 I try to use CSV with feet values and centimeters but none display correctly during importation.  the new helpd guide is not complete and need more details from this topic
				Well, it seems like a call to hummingbird is the next step.
