General => General Discussion => Topic started by: G.R.U.F. on February 16, 2016, 11:32:29 PM
Title: Multiple maps with Autochart
Post by: G.R.U.F. on February 16, 2016, 11:32:29 PM
Can you put more than one lake on the  AutoChart Zero Lines map card
Title: Re: Multiple maps with Autochart
Post by: rnvinc on February 17, 2016, 10:40:06 PM
Zero Line card
Specifications
32 GB SD card containing zero lines for with over 140,000 named water bodies and over 1.75 million unnamed water bodies in the United States and over 96,000 named water bodies and over 3.85 million unnamed water bodies in Canada. Plus there is 16 GB of free space to maintain your custom maps.
16 GB will hold a lot of lakes ...
Post by: fishreed on February 28, 2016, 09:27:41 PM
Zero Line card
Specifications
Doesa  person have to buy a Lakemaster chip to use Autochart?
Post by: rnvinc on February 29, 2016, 10:00:26 PM
Mapping created with the PC based AutoChart or AutoChart Pro must be put onto the LakeMaster Zero Lines card to be used as a LakeMaster map card in the units ...
AutoChart Live can be stored in the unit memory or moved to the LakeMaster Zero Lines card ...
None of the AutoChart products can be loaded to a regular SD Card and used as a LakeMaster mapping card ...
Sonar recordings and track recordings will use a regular SD Card ...but only for getting that data into the AutoChart PC program ...
The Zero Lines card becomes a regular LakeMaster map card ...which can be used in the unit as is ... or overlayed onto LakeMaster data from another LakeMaster map card ...
Post by: fishreed on March 01, 2016, 10:22:49 PM
So...are you telling me if I have a Helix 10 I have to buy another piece of software to use the Helix 10's built in Autochart software?
Post by: rnvinc on March 02, 2016, 02:07:24 AM
No ... The AutoChart Live feature built into the HELIX 9, 10, and 12 has 8 hours of internal memory capacity ...
After that 8 hour segment of unit memory is used ... The AutoChart mapping starts overwriting the earliest map data created ...
If you want more than the 8 hours of internal memory mapping capability ... You must buy a Zero Lines card ...
Post by: fishreed on March 02, 2016, 07:49:44 AM
So what happens if I have an empty  16gb SD card in the other memory slot?
Post by: rnvinc on March 02, 2016, 10:26:27 PM
Nothing ... AutoChart map data can only be put on the Zero Lines card ...
The regular SD Card can be used for Sonar recordings or exporting track data to ... And then uploaded into the AutoChart PC program for conversion to map data ...
You can create AutoChart Live to internal memory and record sonar data to the regular SD Card at the same time ...
Post by: rnvinc on March 02, 2016, 10:28:24 PM
The AutoChart Live and the AutoChart PC stuff are 2 completely different animals ...and cannot be intertwined in any way at this time ...
Post by: ricqik on March 07, 2016, 07:19:32 AM
Does that apply to zero line sd card. If I insert a zero line sd card in a helix 9,10,12, will it record live mapping onto the card or do I still have to record to a regular sd card then convert through pc and reload into zero line to work.
Post by: rnvinc on March 07, 2016, 10:30:27 AM
If you have AutoChart Live data already stored in the HELIX 9, 10, 12 memory ... It will be automatically transferred to the Zero Line card when you insert the Zero Line card ... The unit also immediately erases the internal memory of AutoChart Live data ...(in other words you get no choice whether to transfer internal AutoChart Live data to the Zero Lines card ... And you get no choice that the internal memory is erased of AutoChart Live data) ...
I'm still trying to find verification that AutoChart Live data can be written directly to the Zero Lines card in the HELIX series... (It is an option in ONIX) ...
Post by: rnvinc on March 07, 2016, 10:44:47 AM
Any Sonar recording cannot be used for AutoChart Live data ...
Sonar recordings and saved track data can only be utilized via a regular SD card, imported into the AutoChart PC product, rendered into mapping data, loaded onto the Zero Lines card, used in any LakeMaster capable HB unit ...
The AutoChart Live product is completely different from AutoChart PC and AutoChart Pro PC products ...
Both products do use the Zero Line card ...because the Zero Line card will be a regular LakeMaster mapping card (but with your personal mapping data) ...
It's confusing because HB uses the same "AutoChart" moniker for both the AutoChart Live product and the AutoChart PC products ...
Capturing the data/manipulating the data into custom maps/using the custom map data/ which units will utilize which AutoChart product are not the same ...
AutoChart Live mapping data can only be used in AutoChart Live capable units ...
AutoChart PC mapping data can be captured/rendered into mapping data and used in any LakeMaster capable HB unit ...
Post by: ricqik on March 07, 2016, 11:31:12 AM
Cool, no more messing around with pc.
Post by: ricqik on March 07, 2016, 06:03:19 PM
This got me thinking. If what you say above is true. Then one could simply map with a helix 9,10,12 and insert zeroline card and voila, no autochart pc needed. Ready to insert the now plug and play zeroline card into core units such as 1199s. Am I right.
Post by: Bob B on March 07, 2016, 09:30:24 PM
Unfortunately an Autochart Live map won't work on the core units....only units that have Autochart Live built in.
Post by: ricqik on March 07, 2016, 09:47:52 PM
aw shux.
Post by: rnvinc on March 08, 2016, 10:26:52 AM
I guess I put so much info in my explaination that the above in blue was missed ... Sorry ...
