General => General Discussion => Topic started by: rnvinc on March 17, 2010, 12:46:22 PM
I have several recordings on my SD card.....
I frequently take the SD card out of the 1197 to work with the recordings on my pc....HB PC, Humviewer, etc.....
When I get ready to put the SD card back in the 1197 unit......does it matter if the unit is on or off....??
Should not make a difference unless you have added a software change. if all you do is to copy over to your pc then it will be fine to insert with power off. or if you forget you can put it in with power on. If you add old files like recordings or snapshots it will be ok also. chuck
