Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: fishbone on September 24, 2015, 12:33:37 PM
I am considering the 999 for a bow mount.
I have a five year old console mounted 998 that is easily washed out by bright sunlight. It would not be usable in a bow application.
Are recent versions brighter and able to be used in a somewhat flat (up) display angle?
The original 998 SI Combo had CCFL backlighting (which I assume yours is if your unit does not physically have "HD" in the model name and printed on the SD Card slot door) ...
The 998 HD SI Combo had LED backlighting (which was the only change made with the added "HD" designation ... It is easier for sunlight viewing)
The 999 HD SI Combo also has LED backlighting (which is easier for sunlight viewing) ...
Thanks, Rickie
