Other Humminbird Products => Lakemaster AutoChart => Topic started by: d.sonnenburg on July 28, 2015, 02:52:13 PM
Title: mapping outside of parameters
Post by: d.sonnenburg on July 28, 2015, 02:52:13 PM
I recently mapped a lake and uploaded the data to the computer. I created an outline of the lake as a kml. file in google earth. now when it makes a map it goes beyond my outline and maps land area thus wrecking my map. all of my sonar recording are within the outline that i made so i have no idea why it is showing data outside of this area. Any help would be much appreciated. Thanks!
Title: Re: mapping outside of parameters
Post by: D S on July 30, 2015, 12:48:28 AM
d go to
tools..setting...general ..
look at shorelines
and make sure you have selected your shorelines  and that it isn't using the default shoreline as it is often off by quite a bit
for your own impoerted kml file
try
use shorelines
user defined data
see if that helps
ds
Post by: d.sonnenburg on July 30, 2015, 02:31:16 PM
I already had it set up that way. but thanks!
Post by: CamoHunter on July 31, 2015, 12:44:50 PM
After you imported the Google Earth .kml file, did you remember to open the autochart file for your shoreline, and change the data type to shoreline?
pages 28-36 here:
https://drive.google.com/file/d/0B2IE_4njdjrPMU5NcV9QQkY4cG8/view?usp=sharing
